E350 (2003) parking brake question
Looking for some advice on changing the brake shoes on a 2003 E350 Super Duty. I was able to get the disc brake caliber off, the housing for the caliber off, and even the combined disc/drum came off easy. So the question is do I try to change the shoes with the axle hub still on or do I have to remove it? My axle hub does not look like the others I have seen on-line or in videos--no ring of bolts to get to the bearing. So is there a special tool that will fit around those 2 triangular shapes so I can remove the axle hub? Any advice from the wise ones here would be greatly appreciated.
2003 E350 parking brake shoes
First of all: those shoes look to be in great condition.
Second: they are only used for the parking brake/emergency brake, so it’s no surprise they’re in excellent condition. They aren’t used whatsoever for slowing your van in regular driving.
**Why do you have any interest in changing them?
Thanks for your reply Im50fast. I thought they looked good too. Only got the E350 in Dec. '17 and it has not had any parking brakes in that time. I see I will need to research this more--I read a number of others with no or weak parking brakes. I got new rotors--the disc was too worn. I'll check on the rest of the parking brake 'stuff' next.
i don’t understand.
Yes, the parking brakes don't work at all. The regular disc brakes work fine. This van spent most of it's life as a wheelchair van for the state of TN; very little rust for an '03 with 140k miles (see photo). I think I will start at the parking brake pedal and work my way back to the shoes. Also, when I bought the van the only code (see photo) was a problem with the brake light on the instrument panel--which led me to believe it had been driven with the parking brake on. Now I need to investigate this too to see how it all fits together.
Rear brake driver side
Just sharing my opinion here; but who cares about the parking brake? Why bother?
ive driven well over half a million miles in my 23 years of driving and never once used a parking/emergency brake for anything other than goofing off and getting the rear end to slide around.
Why do you care about it?
I have looked at this axle and done some research. To remove this axle and wheel flange will be more work than I want to do right now. I checked the parking brake and it does move (slightly) when the pedal is pushed, so I will try to adjust the brake shoes/star nut to see if that will fix the problem. What is really strange is that most E350 van brake photos I can find have very different ends--usually the end has a number of bolts holding the end of the axle in place--you remove the end and can get to the bearings. I think I would either need to get into the diff. and remove a retaining clip or else remove the large bolts behind the parking brake backer plate and remove the entire thing. I will update about I adjust the brakes, hopefully this weekend.
Update on the parking brakes. I have worked on both rear brakes. The disc rotors were worn past spec. so I replaced both. I cleaned the parking brakes and adjusted them so that they 'somewhat' work--will hold on flat or slight incline but not on steeper hills. The cables are not adjustable so I am looking into seeing whether the cables have stretched--the parking brake pedal depresses to the firewall. As far as the parking brakes themselves, they do not appear to be self-adjusting--I saw no lever to turn the star-bolt; since these are only parking/emergency brakes it makes sense that they would be manually adjusted.
