Midfifty Panel Rear Window Seals don't fit?
Old 03-08-2018, 08:36 AM
zolav8's Avatar
zolav8
zolav8 is offline
The piece of glass I have also has the Ford logo stamp on it and the measurements in yellow are the same as mine
In that case I'll make a cardboard template with the dimensions is yellow and check if it would fit in my window openings.
If it fits, I'll get new glasses, if it doesn't, I have to cut the seals.
Old 03-08-2018, 09:14 AM
56panelford's Avatar
56panelford
56panelford is offline
Received 4,108 Likes on 2,642 Posts
If you are not in a real hurry I can trace the glass I have and mail it to you, if this works PM me your mailing address and I'll get it in the mail right away..
Old 03-08-2018, 09:29 AM
zolav8's Avatar
zolav8
zolav8 is offline
Great idea, thanks!
Old 03-08-2018, 10:03 AM
filthy6's Avatar
filthy6
filthy6 is offline
Sounds like a good back and forth between you and Mid Fifty working toward a solution or understanding. I ordered windshield rubber for a '56 f100. It was the wrong size apparently from the supplier. They corrected the situation and I was pleased with their service. Pleased until I broke the windshield..............
Old 03-08-2018, 11:29 AM
Y-Block Limey's Avatar
Y-Block Limey
Y-Block Limey is offline
I think your doors are from an earlier panel van - such as a '48 F1.
Hang on - I'll try to get sone photos for comparison...
Old 03-08-2018, 11:33 AM
Y-Block Limey
Scratch that. Yes, earlier windows are smaller, but you look to have the right ones for the model year.
Old 03-08-2018, 12:23 PM
49f3dls's Avatar
49f3dls
49f3dls is offline
The correct year doors, the glass came out of those doors, yet the glass is smaller than what others have. Do you still have the rubber seals or part of them to see if they are thicker therefore the glass is smaller? Have you measured the door opening - sorry if I missed that post and am asking again. Maybe good old Henery had different doors for diffenernt plants.
Good luck
Old 03-08-2018, 12:31 PM
Aloha-boy's Avatar
Aloha-boy
Aloha-boy is offline
Could it be that the previous owner had a different seal that accommodated the smaller glass?
Old 03-08-2018, 01:37 PM
abe's Avatar
abe
abe is offline
One Meadow Green Owner
Received 2,597 Likes on 1,443 Posts
But the question is, why is the glass smaller?
Old 03-08-2018, 01:44 PM
abe's Avatar
abe
abe is offline
Here is a collection of 53 to 56 panel truck doors. How do these compare to Zolas?
Old 03-08-2018, 01:49 PM
56panelford
53-56 is the only doors that will fit on the back of a 53-56. It's quite possible the rubber he was sent were cut too long before the ends were joined..
abe's Avatar
abe
abe is offline
Here are Zolas doors on the same page to better compare.
Originally Posted by zolav8
Dave, I 'm sure that I have the correct doors.
  #28
Old 03-08-2018, 03:22 PM
zolav8's Avatar
zolav8
zolav8 is offline
Thanks for the tips!
Unfortunatelly I threw away the old seals, but I can still try to insert the new ones in my window openings.
If they are correct, I have to get new glasses.
John will mail me a template.
  #29
Old 03-08-2018, 05:59 PM
56panelford
It was put in the mail and is on it's way..
  #30
Old 03-08-2018, 11:23 PM
zolav8's Avatar
zolav8
zolav8 is offline
Thanks!
Quick Reply: Midfifty Panel Rear Window Seals don't fit?
