2008 Ford Escape...clicking noise inside vehicle - Ford Truck Enthusiasts Forums
Go Back  Ford Truck Enthusiasts Forums > Small Chassis Trucks > Escape & Escape Hybrid
Reload this Page >
Escape & Escape Hybrid Ford Escape, Ford Escape Hybrid, Mercury Mariner, Mazda Tribute
Old 03-03-2018, 11:28 AM
Beau Waldrop
Beau Waldrop is offline
Beau Waldrop is starting off with a positive reputation.
Hello all,
Recently a clicknoise has started happening a few seconds after I start the vehicle. It clicks a few times, stops, then repeats. I don't believe it happens the whole time I'm driving, but it does continue for a bit. It's not coming from my engine, IT's coming from inside my vehicle. I listened and don't think it's coming from my steering wheel. It could be coming from my ignition, but it sounds as if it's a little further back. I recorded sound of it in hopes someone can tell me what it is and if it's something I need to get fixed right away.
Any ideas?
Old 03-03-2018, 07:17 PM
got2bjoester
got2bjoester is offline
got2bjoester is gaining momentum as a positive member of FTE.
If I'm not mistaken, this has the electric power steering column. It sounds to me like there is some sort of calibration or something as power is first applied.
I know there was a recall for the steering. I would make sure the recall work was done for starters.
Old 03-09-2018, 05:30 PM
5_labsownus's Avatar
5_labsownus
5_labsownus is offline
5_labsownus is a splendid one to behold5_labsownus is a splendid one to behold5_labsownus is a splendid one to behold5_labsownus is a splendid one to behold5_labsownus is a splendid one to behold5_labsownus is a splendid one to behold5_labsownus is a splendid one to behold5_labsownus is a splendid one to behold
Blend door actuators make about that same sound sometimes when failing. If you could better isolate the area it coming from would help. Key off, Key on Engine off or running?
Old 03-13-2018, 09:16 PM
SWSL
SWSL is offline
SWSL is starting off with a positive reputation.
Actuators or a relay of some sort. Blend doors sounds like a good suspect. Would that be under the seats or if a relay then console dash?
Could try fooling with the AC/heat output (defrost or just AC) to see if that eliminates noise.
Could use a tube into ear, stethoscope style to see if localizes behind dash or under seat.
moddermt
01-27-2017 02:49 PM
Pigman54
10-31-2014 12:37 PM
Zephyrhills Ford
07-21-2010 10:20 AM
fitzy67
1997-2006 Expedition & Navigator
08-04-2008 06:13 PM
kert
09-14-2007 10:43 PM
Quick Reply: 2008 Ford Escape...clicking noise inside vehicle
Contact Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
