1977 300 I6 clutch
1977 300 I6 clutch
My 300 with a 3 speed manual column is having a severe clutch chatter problem (it shakes the whole truck) but once I get going it’s smooth. I’m new to transmissions so I really have no idea what size of clutch I need there’s all these input shaft dimensions and etc. Anyone have the “ultimate 300 i6 transmission guide” or something?
I'm gearing up for a zf swap, and am using the clutch out of a f250 with a 351w. Bolts up perfect.
I'm surprised you liked the Luk clutch. I purchased one and it looked so rinky-dink that I sent it back to Summit. I went with a Ram.
RockAuto only list a 11" x 1 1/16" 10T for 77 F150's. But they also don't even list a manual transmission for the 77 F100. So you can't go by everything you see listed there.
I've had good luck with the Luk clutches for stock replacements. As long as you aren't going to be doing any high rpm clutch dumps they are fine. I bought a Valeo clutch for my 89 E350 manual swap.
The clutch company I avoid buying from is Zoom. I spent $400 on a clutch kit for my 54 project and it showed up with all the parts loose in the box and the zoom box destroyed. The zoom box was nicely packed in a damage free Summit racing box. I contacted Summit Racing and was told that is the way Zoom ships them. Even the dirt cheap imported clutches I've bought in the past have came with the parts vacuum sealed down or had some kind of inner box structure to hold it all securely down.
Also, regarding the ten or eleven inch clutch: I had only looked at a 91 f250. There, I'm certain, you can see that Ford used the 10" on lighter vehicles.
Well, maybe the Luk would have worked fine. My point is that 'it looked rinky dink.' By rinky dink I mean cheap, toyish, inferior, flimsy. So much so that I returned it. The difference in quality between it and the Ram was plain to see. However, I may have purchased a cheapo model of the Luk. Don't know.
Yes the 80+ had 10" & 11". I don't know on the 79 and older. But even if the 10" was offered why would anyone buy one?? The truck flywheels I've had, have all been drilled for both. So even if they came with a 10" I always buy the 11" for them.
bad a$$ roth
06-20-2012 05:59 PM
towtruck1
08-07-2007 12:44 AM
