Corroded radiator oil to water trans cooler fitting
I bet it's because he's thinking those lines are to your trans cooler, not the rad, and he's suggesting along with the fix you wanna do, you should also do the common upgrade most people do and replace the really small 7.3L trans cooler, with the 3 times larger 6.0L trans cooler.
But that's just a guess...a flying leap, as you will, at the proverbial rolling donut.
Stewart
Stewart
And just for specificity sake for anyone reading in the future, it's only part of the 2000 MY run. Some point midway through the 2000's Ford put the cooler back in the rad.
Stewart
You'll need adapter fittings to make it work, but it's not difficult.
Stewart
The 6.0 basically mounts where the original 7.3 cooler sits now. there are lots of 6.0 cooler install "how tos" out there. My 2000 didn't have the radiator cooler and I'm running the 6.0 cooler. I have never seen high temps, but I don't tow heavy. I'm with Stewart, fix your radiator and keep that portion of the cooling system working.
Not if you have the fix that swept the Internet last year!
https://chrome.google.com/webstore/d...giikdkpmcpkaon
https://addons.mozilla.org/en-US/fir...t-fix/?src=api
Add those to your toolbar and voila, pics are hot linked again.
Stewart
Stewart
on
...until the next workaround, or PB decides to files a lawsuit because these kinds of addons deliberately circumvent their attempts to block access to their servers.
Wouldn't it be better to simply upload them to the FTE servers?
Oh... ...wait a sec....
You were serious, weren't you?
While I do use the FTE uploader frequently, there's no way FTE's software is complex enough to allow me to copy the hundreds and hundreds of pictures I have over there, transfer them to over here, and be able to organize them in a useful, user-friendly manner.
Stewart
on
None of which really affect me.
Stewart
Stewart
on
Thought I kept the fittings, but no. I removed them last Spring from the radiator when I replaced it. Can't find them.
Pretty sure the new radiator came with the new fittings.
If I could find them, I was planning to send them to you, eliminate the rusty part to mate up to your new lines. But apparently I can't do that. Sorry, buddy.
Maybe someone else who has replaced their radiator has kept the fittings?
#28
Ah, there's another thought! It's a bad idea to eliminate/bypass the in-rad trans cooler, but you're correct, it's another possible way he meant it.
Stewart
Stewart
am I mistaken? You can bet that when I'm under there today I will check.
#29
Part #s
Found the following for the drivers side...
http://www.jegs.com/i/Dorman-Product...0aAl45EALw_wcB
but can't find passenger side...
#30
on
Are you looking to replace the entire line from the transmission to the radiator?
Here's my thread where I fixed my 6.0 cooler installation. Fair number of pics that might be able to help you see what lines are needed and where. It also has my new radiator install in the thread
https://www.ford-trucks.com/forums/1...tall-pics.html
