Ok I’m a little confused. Since I’ve joined in on the conversation (last 1/2 hr or so) you have found the 12 pin wires that were zip tied around the spare tire. You’ve plugged those wires into the new harness and you’ve plugged the 40 foot harness that runs from the camera; checking those connections as well ( ito camera and where it branches to the TPMS Module)
The nly connection between the pigtail and the camera appears to be where the camera cable plugs into the final pigtail harness, and that connection seems to be tight. I didn't do the install on the trailer, the trailer builder did, but I traced the entire routing of the cable and didn't see any loose connections
Thanks for the link. The evidently sense the TPMS because trailer set up calls for it. I haven't had the sensors installed yet so I skipped that part of the trailer set up. I wonder why it senses the TPMS but not the camera.
Only thing I would suggest is check power and continuity at the camera end. Simple light tester will at least ensure you have power. Then check the ohms
I decided not to screw with it. Letting my trailer dealer do the camper wiring. Will have my truck dealer do the truck wiring and then we'll see if it all comes together. I'm not crazy. Trailer is stored at the In-laws farm 10 hrs away.
I am like you, I had the trailer builder install the trailer side. I helped his man do the truck side. I am pretty sure the truck side is right. I mean, if the truck is sensing the TPMS but not the camera, it almost has to be the camera side somewhere.
Verify the connector at the camera is actually plugged in. It connects inside the housing, so it's a little wierd to make the connection.. not hard, just weird.
