2000 F350 clock/radio display dim
Old 02-24-2018, 06:37 PM
papajohn3's Avatar
papajohn3
papajohn3 is offline
a few months ago, the display on my clock/radio started getting less bright, then noticeably dim, dimmer, and now no display. If I tap on the display 'glass' it may, or may not, come back, but then slowly dims an goes back to no display.
All other functions work just fine - just not display.
I've taken the clock/radio out and apart and re-soldered four resistors that appear to be part of the circuits feeding the display controller on the circuit board behind the bezel but no fix. The display did come back for a short time but then faded out to no display.
It appears that there is a loose solder joint or connection somewhere that effects only the display.
Does anybody have any idea where I should look next for a loose connection - or what else might be causing this display problem?
Thanks for any help on this.
John
Old 03-05-2018, 04:21 PM
papajohn3's Avatar
papajohn3
Final update on my clock/radio display problem -
Took it out of the truck again today for a second look at the circuit board.
Found another couple of likely candidates - black rectangular about 1/4" long with a number on the top.
In the process of re-soldering one end of one of them I found that the soldered joint at the other end had broken loose from the board.
Soldered that end and, as well, re-soldered both ends of the other part.
Reinstalled the radio and - miracle - the display is as good as new now.
papajohn3
1999 to 2016 Super Duty
03-05-2018 04:20 PM
redranger1
05-26-2013 08:20 PM
danny99
12-27-2006 08:16 PM
FalconFXR
1983 - 2012 Ranger & B-Series
11-15-2003 10:48 AM
alancp
03-25-2003 06:47 PM
Quick Reply: 2000 F350 clock/radio display dim
