Gage cluster dim - Page 2 - Ford Truck Enthusiasts Forums
Gage cluster dim
Old 02-27-2018, 03:44 PM
arapf
arapf is offline
arapf is starting off with a positive reputation.
here are the LEDs I ordered.
Old 03-10-2018, 03:01 PM
BadMoFo
BadMoFo is offline
BadMoFo is starting off with a positive reputation.
Just 5 bulbs in my cluster but got the wrong bulbs. Originals are GE 194. So much for doing that today. Also the harness that plugs into the cluster wasnít fully seated but I donít know if it came out when I was removing the cluster or before. And the only other thing attached is the speedo cable.
Old 03-10-2018, 03:35 PM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
Originally Posted by GaryKip View Post
Here is the instrument panel:
Yours will be the top one.
Upper pic: Backside of 1970/72 F100/350 instrument cluster. 13711 are the bulb sockets, 11654 is the headlamp switch, 11572 is the ignition switch, 17A553 is the wiper switch, 15055 is the lighter socket.
Old 03-10-2018, 03:47 PM
BadMoFo
BadMoFo is offline
Ok it appears I donít have a turn signal flasher?
Old 03-10-2018, 04:22 PM
NumberDummy
Here's the pic of the T/S flasher and 4 way flasher locations for 1970/72 F100/350. Why your instrument cluster doesn't have a place for the T/S flasher, I dunno.
Old 03-10-2018, 04:49 PM
BadMoFo
BadMoFo is offline
Which is weird as all my lights work except for my passenger side front marker light. The blinker works, just not the marker.
Old 03-10-2018, 06:47 PM
Thipdar's Avatar
Thipdar
Thipdar is offline
Thipdar has a good reputation on FTE.Thipdar has a good reputation on FTE.Thipdar has a good reputation on FTE.
That little hole in the upper right of the picture is where the flasher mounts.
Check this picture:
Your flasher is probably hanging behind the dash.
The top of the flasher housing is supposed to have a small protrusion that fits into the elongated hole... then you twist it 90-degrees to keep it in place.
Looks like this:
Some of the contemporary replacements don't have this protrusion. Other users have cut off the top of the housing from their old blinker and epoxied it onto the replacement. Other folks just let it hang in that area behind the dash.
The flasher is generally the last thing I hook up before I put the screws back into the Instrument Cluster. It's a little easier to see what you need to do that way. It's possible to re-install a flasher when the Instrument Cluster is still installed, but it's a little awkward to do it by touch.
Old 03-11-2018, 11:47 AM
arapf
arapf is offline
Yeah, your cluster doesn't look like mine. The bulbs I ordered (LED) work great, love them but they don't dim...oh well. not a big deal.
Old 03-11-2018, 10:54 PM
meangreen92's Avatar
meangreen92
meangreen92 is online now
meangreen92 has a very good reputation on FTE.meangreen92 has a very good reputation on FTE.meangreen92 has a very good reputation on FTE.
If you're staying with incandescent bulbs, then don't use 194s for the positions which light the gauges. Get 168s. They look identical, but put out three lumens vs. two lumens from the 194s. I swapped the two illumination bulbs in my rig ('77 F150) to 168s, and the gauges were as bright at idle as they had been at 2000 RPM with the 194s!
Old 03-12-2018, 05:54 AM
BadMoFo
BadMoFo is offline
no I went ahead and purchased more led bulbs just have to wait for them to show up.
Old 03-14-2018, 05:47 PM
BadMoFo
BadMoFo is offline
Ok looked at the turn signal that stays on and the stuff around it looks intact. It was mentioned somewhere else that it may be the turn signal switch but was told to check the ground strap. Googled a picture and it shows a ground strap going over the rag joint, is that right? And if so I donít have one.
Old 03-15-2018, 02:56 AM
GaryKip's Avatar
GaryKip
GaryKip is offline
GaryKip is a splendid one to beholdGaryKip is a splendid one to beholdGaryKip is a splendid one to beholdGaryKip is a splendid one to beholdGaryKip is a splendid one to beholdGaryKip is a splendid one to beholdGaryKip is a splendid one to behold
You can fab one up super easy. A couple of ring terminals and a piece of 14ga or 12ga wire- time to find the wrenches.
  #28
Old 03-17-2018, 03:18 PM
BadMoFo
BadMoFo is offline
Ok found turn signal flasher behind dash, itís metal and doesnít have a tab to connect it to the cluster. Think there are still some electrical gremlins as I replaced the bulbs with new leds and it looks way better, however, the issue with the blinker light staying on is gone but now I have no indicators when I turn the blinker switch. I can hear it clicking, my outside lights are blinking, dash I got nothing.
  #29
Old 03-17-2018, 10:07 PM
Thipdar's Avatar
Thipdar
Thipdar is offline
Can you confirm that you checked the Instrument Cluster with the connector plugged into the Cluster?
Other than that, I'd guess that your blinker is going out, or the Instrument Cluster Constant Voltage Regulator is't putting out enough to drive the blinker.
  #30
Old 03-18-2018, 11:09 AM
arapf
arapf is offline
Hi GaryKip (or anyone else with the answer. Where do you get these diagrams? They seem pretty helpful and would like to have access to them.
Quick Reply: Gage cluster dim
Contact Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
