Questions on 302 compression ratios
I rolled the engine over this afternoon, and I can see the number D90E6110 AA cast into the backs of the pistons.
Can't find much on Google, other than what is linked below:
YEAR -- PART # -- Material/Type -- Weight (g)
79-84 -- D9OE-6110-AA -- Sand-Cast Aluminum/Four Valve-Relief Eyebrows -- 470
https://www.stangnet.com/mustang-for...erence.621796/
Just FYI really, nothing more.
The only "stock replacement" pistons I've found are the Speed Pro L2482 which is an older 302 type piston (as far as I know) and the other is L2488 which is a replacement for the 5.0 HO motors. The L2482 has 2.7cc valve reliefs with a 1.605 compression height and the L2488 has 2.0cc valve reliefs with a 1.619 compression height.
There are several ways to get the compression you want. Milling the heads and decking the block are some things I would recommend on a rebuild which sounds as thorough as yours. The head gasket compressed thickness can also be reduced but I've seen that doesn't get as much compression as the other mentioned ideas.
What I'm getting on my calculator is if you can reduce the deck height down to about .007 and your combustion chamber to about 59cc you could get 9.5:1. And that's with a 4.00 bore and a .047 head gasket. That's with the 2.0cc valve relief too.
Are you saying just that year which I think is highly unlikely or just the mid eighties blocks or ? Or generally speaking about newer '85ish and up roller blocks? I get that the 5.0 blocks ('85ish and up) were the lightest, thinnest blocks. But looking at his lifter valley this isn't a roller block.
on
The HO firing order is easier on the crank and bearings but that's not a hugh deal on anything but an all out racing motor. That 31-230-3 grind sacrifices some peak HP for a little more lowend torque... it's down to 275hp and peak TQ is about the same but there is about 20lb/ft more at 2000rpm.
The E0AE block is the thinnest lightest of all 302/5.0 blocks. (120 lbs)This is the block used from 1980 to 1984. The 85 Roller block was 2 lbs heavier, due to the added iron to raise the lifter bores to fit the roller lifters. The 86-up blocks got another 4 lbs added to the decks to stiffen them, apparently the 1980-85's had sealing issues. The pre 1980 blocks all weighed in at 136 lbs. This included the Mex blocks. I have personally weighed a 69, a 72, 2-78's and all weighed in at 136 lbs. One of the two 78's had the same thick main caps like the Mex and 289 Hi-po blocks. The casting suffix for that block was A3A. The other was 3A and had the regular small caps.
Considering the stock specs were something like 133HP and 250lb/ft torque, it should work and feel much better @ 275 HP and 335 lb/ft torque.
Thanks again.
Rem
Get Ford's "The official 5.0 Manual" published by Ford Racing. The block weights are in there along with lots of other specs for the 1980-up 5.0's along with some info for the earlier 302's. The D8VE- A3A blocks with the thick main caps I've run across on my own. I've had others come up with these blocks too on a few forums after seeing me mention them. The bunch I weighed (bare) were some I got with a bunch of Bronco parts and stripped down to scrap and sell the usable parts. Just out of curiosity, I weighed those 4-5 blocks to see how they compared to the Mex block weights. The only thing special about the Mex blocks was the main caps, they're otherwise the same as far as weights as the rest of the early, pre 1980 blocks.
This one below linked on Amazon?
I purchased two SBF books, and they're decent enough for casual reading, but kind of a generic overall, and focused mainly on 1980-older stuff.
Does the Official 5.0 manual make any reference to what the CC volume is of the 4x valve reliefs in my flat-top pistons?
I've found varying info online. I've read that the pistons in the 87-93 5.0 engines, with the slight dished section in addition to the valve reliefs was 5cc, but I also came across info stating they were 5.5 cc, and 6cc. I found other comments that the true flat top pistons with 4 valve reliefs were 4.6cc, and 3cc.
https://www.amazon.com/Official-Ford.../dp/0837602106
According to my math, 0.007" in a 4" bore equals 1.44 CC, but the area of the chamber is only about 2/3 of that, so the 1 cc per 7 thou seems correct...at least in the approximate sense.
#28
Thanks for the info, much appreciated. I've read that, with the GT40 heads, approximately every 0.007" machined off equals 1cc. Does that sound about right?
#29
As for the other books on the older Ford engines, you really have to buy and read all of them to find the mistakes in them. And there are a few mistakes. The Ford racing book may have some too, but I've yet to see anything obvious in it. It may be written by the author, but the info I assume was sanctioned by Ford looking at it's title.
#30
They've been very helpful, but they're just kind of a generic read on the basics. There are some good details, and a few pages of specs here and there, but I found a couple mistakes myself. They really are aimed more at the pre-roller block era SBF's, and more specifically at the 1970's stuff. I'm not complaining...as a new guy with this stuff, they were good reading to get up to speed on the basics.
Thanks for all the replies/help. Much appreciated.
I'll report back with details after this thing is assembled and tested.
