installed used steering column
Old Feb 22, 2018 | 07:16 PM
mark flaherty's Avatar
mark flaherty
I was given a 03 expedition with a mangled ignition. I bought a used steering column with a key and now it wont crank over. How do I fix without going to the ford dealer?
Old Feb 22, 2018 | 07:44 PM
alwaysfords41's Avatar
alwaysfords41
I’m no pro, but that is a PATS key that needs to be programmed to the vehicle.
Old Feb 23, 2018 | 08:01 AM
alloro's Avatar
alloro
By that do you mean the engine won't start or the starter doesn't turn?
Old Feb 25, 2018 | 04:51 PM
Mini1298's Avatar
Mini1298
The key will needs to get relearned to the pcm, it’s the pats(anti theft) that’s keeping it from turning over. Unfortunately. A trip to the dealer or any independent shop with an IDS, program the key and it should be good to go.
Old Feb 26, 2018 | 01:37 PM
Skauber's Avatar
Skauber
If you're familiar with computers and have a good OBDII bluetooth dongle, you can program keys using FORScan. (free on Windows What's new )
It's not too difficult, I did this on my own vehicle.
Old Feb 26, 2018 | 06:03 PM
kythri's Avatar
kythri
I thought PATS disabled the fuel pump or fuel injection system, not the starter?
Old Feb 26, 2018 | 06:30 PM
Mini1298's Avatar
Mini1298
Everytime I have installed a used PCM or column in any ford with PATS, it will never crank over till the key is learned, the theft light will just flash, and trust me, I’ve replaced a lot of ford PCMs for multiple issues.
Old Feb 27, 2018 | 12:27 AM
Skauber's Avatar
Skauber
Actually, it depends on the model year in the Expedition. The early PATS systems would allow cranking, but disabled the injectors if the key wasn't recognized. The later PATS would disable the starter as well.
Look at this for reference:
https://www.motorcraftservice.com/pdf/pats_job_aid.pdf
Old Feb 27, 2018 | 08:07 AM
projectSHO89's Avatar
projectSHO89
Starter interrupt was done on select models all the way back to their first use of PATS. F150s started getting the interrupt feature beginning in 2004 NBS. Expys began in 2003 MY.
If the OP still has the original key, do a "redneck PATS bypass" to get it going.
Old Dec 17, 2023 | 10:34 PM
20Questions's Avatar
20Questions
1st Gear
is that also the case if you just change columns out and keep old ignition and key to use?
Jdolson22
Aug 22, 2017 12:07 PM
cobrarep
Aug 27, 2008 10:23 PM
cobrarep
Aug 26, 2008 10:56 AM
blueovalboy_69
1997 - 2003 F150
Jul 9, 2008 10:31 PM
ipb1963
Electrical Systems/Wiring
Feb 11, 2003 11:24 PM
