Fluid Film Undercoating
They salt heavily in N Idaho. I apply fluid film every year or two and it does slow corrosion very well. I’ve tried por15, rust bullet, and epoxy primers which all failed. In fact I never paint anything under the vehicles I use during winter as they all fail irregardless of prep. Rinse the underside of the truck in the spring and it will last.
I've used Fluid Film for 7-8 yrs. My '89 F150 came from down south and the frame was still shiny black. I sprayed it twice a year and when I sold it, it was still rust free and that is a marvel after 7 yrs in Ohio weather. I cut it about 50% with used motor oil(I have plenty to get rid of).
I've sprayed my '95 and it is the same way. It won't stop rust that has started, but will keep clean metal rust free.
Yes, it does make a mess but considering the options I put up with it.
I remove the tailgate panel and brush it on thick, I pull the door panels too. inside the front fenders, front of hood, I drill a hole in the upper inner fender of the bed and spray around the top of the lip and put a body plug in. It seeps out for quite a while, but it won't rot once the seams are full.
Thank you, it was a ton of work and a lot of fabricating and welding, but I'm really glad I saved it from going to the scrap yard. I did a full write-up on the truck but it didn't seem to generate much interest-
https://www.ford-trucks.com/forums/1519227-my-1995-f150-project-before-and-after-picture-heavy.html
Thanks freightrain, looks like Fluid Film is going to be the way to go.
I do recall your post, your link didn't work.....I added the missing "L" on the end:
https://www.ford-trucks.com/forums/1...ure-heavy.html
Ya, don't forget it will stink inside for a week too when you do the doors. It goes away after awhile.
#28
#29
Beautiful repair you did. I should note from my previous post I do use por15 on the inside of panels and floors and I’ve found it to hold up well to prevent corrosion, just not underneath the vehicle. I’ve found fluid film to work far better than any paint on the undercarriage.
I’m not exaggerating when I say how much salt they use. When they brine is wet it’s like driving when it’s raining only you cannot keep the window clean and on very cold dry days it’s damn near liking driving on a dirt road with all the salt dust kicked up from vehicles ahead. Totally irresponsible and gross overuse of the de-icing agents where I live. Good for the economy though as it destroys roads, bridges, watersheds, vegetation, and vehicles.
