53-56 tailgate latches
Old 02-24-2018, 06:43 AM
48 Steel's Avatar
48 Steel
48 Steel is offline
Originally Posted by mrf-100
thats cool how did you attach the buckle ?
Both parts are welded.
Old 02-24-2018, 11:21 AM
clintonvillian's Avatar
clintonvillian
clintonvillian is offline
Any more pictures of that tonneau?
Did you make it, buy it?
Old 02-24-2018, 02:28 PM
Björn's Avatar
Björn
Björn is offline
Here is a better picture from behind , will your cover hit this ?
Old 02-24-2018, 03:33 PM
48 Steel's Avatar
48 Steel
48 Steel is offline
QUOTE=clintonvillian;17822296]Any more pictures of that tonneau?
Did you make it, buy it?[/QUOTE]
Made the tonneau, mounts, and the locking device.
Old 02-27-2018, 06:06 AM
clintonvillian
It looks like just angle down the bedsides. Did you use a seal?
And what did you do for hinges?
Old 02-27-2018, 06:35 AM
48 Steel's Avatar
48 Steel
48 Steel is offline
Angle iron and no seal. Barrel hinges SEE first picture.
Old 02-27-2018, 08:45 AM
The Outlaw's Avatar
The Outlaw
The Outlaw is offline
I used CPP's hidden latch system. Bought it off of ebay as it was cheaper and with free shipping than from their site. I modified their install a bit to make it a bit more "Stealth". Instead of using the rear mounting screw I welded the hole shut along with the latch to it. My one complaint about the system is that the thumb screw and sleeve they supply is not long enough. When you tighten it all the way it binds on the tailgate. Which will be no good when it's finished painted. I'm going to first try and make a slightly longer sleeve and hope there is enough thread on the stock thumb screw to hold it. But if not I may have to try and find a TS with a longer thread or head to the lathe and make my own. If I go that route I'll most likely make a piece that matches the curve of the tailgate rail and goes the entire length of the hole to make it totally covered.
I also raised the side rails of the tailgate to hide the lath a bit more.
Old 02-27-2018, 08:43 PM
moose79's Avatar
moose79
moose79 is offline
Originally Posted by Björn
only used the thumb latches
Who makes this ?
Old 02-28-2018, 06:06 PM
petemcl's Avatar
petemcl
petemcl is offline
Still Learnin'
I looked at all of those solutions but decided to stick with SS tailgate chains and rubber covers from Macs. I used a SS spring loaded climbers link that I bought at Home Depot as the top part of the latch. If you need a better picture let me know.
Old 06-09-2018, 05:51 PM
tngoldwinger's Avatar
tngoldwinger
tngoldwinger is offline
Does anyone had photos of the two piece chrome latches from Mid Fifty for the tailgate.
IE how and were you have them mounted.
I would appreciate them very much
Thanks in advance
Dave
Picture at top of thread by@burnettd01
Hillbilly Bob has used the latches.
Old 06-09-2018, 07:54 PM
49willard's Avatar
49willard
49willard is offline
I did not buy from mid fifty but very similar. For the latches to stay latched getting the 2 pieces of the latch correctly located is critical. I had to work with it some to get both latches to stay latched.
Old 06-09-2018, 08:42 PM
jniolon's Avatar
jniolon
jniolon is offline
old and in the way
48 steel... what did you skin that cover with ?? aluminum ?? sheet steel... what's the weight ?? and how water resistant is it
thanks
John
  #28
Old 06-10-2018, 11:29 AM
mrf-100's Avatar
mrf-100
mrf-100 is offline
very nice where did you get the cable ends ?and cable
  #29
Old 06-10-2018, 03:44 PM
49willard's Avatar
49willard
The cable ends came from a older ford truck/junk yard, probably the 90's and the cable came from Advance auto. I fabricated the 1/4" ss pieces. The cables come in different lengths. I mocked it up and found cables that were the right length. Difficult to see in the picture, however there is additional bracing on the outer surface of the bedside and bed.
  #30
Old 06-10-2018, 05:30 PM
CharlieLed's Avatar
CharlieLed
CharlieLed is offline
My 2002 Chevy Silverado has the same cables on the tailgate. Fairly common setup for later model trucks.
SumDayDryvr
1947 and Older Ford Trucks
29
06-11-2017 07:24 AM
6t6merc
11-12-2013 07:20 AM
dieselbronc
Large Truck
07-16-2010 01:35 PM
Quick Reply: 53-56 tailgate latches
