53-56 tailgate latches
I used CPP's hidden latch system. Bought it off of ebay as it was cheaper and with free shipping than from their site. I modified their install a bit to make it a bit more "Stealth". Instead of using the rear mounting screw I welded the hole shut along with the latch to it. My one complaint about the system is that the thumb screw and sleeve they supply is not long enough. When you tighten it all the way it binds on the tailgate. Which will be no good when it's finished painted. I'm going to first try and make a slightly longer sleeve and hope there is enough thread on the stock thumb screw to hold it. But if not I may have to try and find a TS with a longer thread or head to the lathe and make my own. If I go that route I'll most likely make a piece that matches the curve of the tailgate rail and goes the entire length of the hole to make it totally covered.
I also raised the side rails of the tailgate to hide the lath a bit more.
Does anyone had photos of the two piece chrome latches from Mid Fifty for the tailgate.
IE how and were you have them mounted.
I would appreciate them very much
Thanks in advance
Dave
Picture at top of thread by@burnettd01 Hillbilly Bob has used the latches.
Thanks in advance
Dave
very nice where did you get the cable ends ?and cable
#29
The cable ends came from a older ford truck/junk yard, probably the 90's and the cable came from Advance auto. I fabricated the 1/4" ss pieces. The cables come in different lengths. I mocked it up and found cables that were the right length. Difficult to see in the picture, however there is additional bracing on the outer surface of the bedside and bed.
6t6merc
11-12-2013 07:20 AM
