New truck new problems - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 02-21-2018, 04:20 PM
Missymay's Avatar
Missymay
Missymay is offline
Missymay is starting off with a positive reputation.
Just picked up an 03 F250 v10 xlt. A couple small things wrong with it but now Iím wondering if they are all related. Door locks donít work on driver or passenger side (wonít even click) auto lights donít come on by themselves and in the morning the truck starts but as soon as I hit the gas it dies until I mess around with the (aftermarket) alarm then it runs like a champ until the next morning so it doesnít seem like itís mechanical. I want a new alarm anyway so I made an appointment and had them disconnect the alarm for now so Iíll see what it does tomorrow morning. Iíve seen that the BSM/VSM can cause issues with the locks and lights. Are these all related? Where is the VSM/BSM? How can I test it? How does After market alarms tie into it?
Old 02-21-2018, 09:13 PM
Evan_P's Avatar
Evan_P
Evan_P is offline
Evan_P is a splendid one to beholdEvan_P is a splendid one to beholdEvan_P is a splendid one to beholdEvan_P is a splendid one to beholdEvan_P is a splendid one to beholdEvan_P is a splendid one to beholdEvan_P is a splendid one to behold
Step 1, remove the aftermarket garbage alarm. Then see if you still have those issues.
Old 02-21-2018, 09:18 PM
Missymay's Avatar
Missymay
Missymay is offline
It was disconnected. The locks still donít work. I have power to the switch so Iím going to try the actuator foil trick posted on here tomorrow. Iíll have to see what happens when I start it in the morning as far as the stalling. In having them install a viper alarm in a week so Iíd like to fix the locks before then at least.
Old 02-22-2018, 09:48 AM
Missymay's Avatar
Missymay
Missymay is offline
Ok well I guess the alarm wasnít disconnected cause this morning I opened my door and the alarm went off. Took me forever to get it to shut off. Starting the truck didnít even stop it. I let it warm up for awhile and hitting the gas still killed it. Turned t off and back on a few times and now itís working great. Since itís only in the morning it doesnít sound like a mechanical issue but Iíll check the fuel filter this weekend. Back to the alarm shop to have them rip the damn thing out!
Old 02-22-2018, 11:19 AM
dynocompe
dynocompe is offline
dynocompe is starting off with a positive reputation.
all your issues sound like they are from the alarm, so yes get it fixed and if done right i would expect all to be well
Old 02-22-2018, 11:20 AM
dynocompe
alarms tie into your door locks
Old 02-23-2018, 09:02 AM
Missymay's Avatar
Missymay
Missymay is offline
Alarm is out. Iím guessing it is shorting somewhere because they showed me where they disconnected the power. They had to take the whole thing out. It still had trouble this morning starting. Iím going to try the temp coolant sensor and fuel filter. Itís just odd that it only does this in the morning. Iím thinking the coolant temp sensor makes sense.
Old 02-23-2018, 09:10 AM
dynocompe
You never said you had trouble starting. But I think thatís an unrelated issue. Try plugging the truck in next time. See how it starts then. It will help focus where the problem lies
Old 02-23-2018, 09:13 AM
dynocompe
I like to change the fuel filter on anything used I buy same with oil and such. But I wouldnít just start throwing parts at the truck. Thatís what the forums are for, figure out the issue and replace parts that are actually needed.
Old 02-23-2018, 09:14 AM
Missymay's Avatar
Missymay
Missymay is offline
it starts fine but dies when I hit the gas. I thought it might be the alarm cause when I messed around with it it would be fine. I donít have problems the rest of the day just first thing in the morning. Itís not throwing any codes when it dies and my reader doesnít do real-time.
Old 02-23-2018, 09:15 AM
dynocompe
What are the temps in the morning? Stiction on the injectors cause hard coldstarts, a bad glow plug. Do you have a check engine light on?
Old 02-23-2018, 09:16 AM
dynocompe
Ohh gas haha sorry was thinking it was a diesel
Old 02-23-2018, 09:17 AM
dynocompe
I would pull a plug and see how they look
Old 02-23-2018, 09:18 AM
dynocompe
Clean maf sensor, throttle body. That is a good start
Old 02-23-2018, 09:22 AM
dynocompe
I canít see an alarm affectIng a cold start. I have only installed plain Jane ones on older vehicles. But nothing would make a rough cold start. I think itís unrelated. But was related to your door lock issue.
Quick Reply: New truck new problems
Contact Us About Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2018 MH Sub I, LLC dba Internet Brands
