Fuel economy on '09 e350
Old 02-21-2018, 08:50 PM
Conanski's Avatar
Conanski
Conanski is offline
Originally Posted by abbyC
What I did to calculate mileage was reset the odometer when I last filled the tank, and went down to just about 0 and calculated the mileage based on what I saw. I had basically gotten 200 miles to the full tank of gas. Is there another way that I should be calculating mileage?
You missed 1 important step, you need to fill the tank up again so you know how much fuel was used for that interval, it will never be the full capacity of the tank because you will never drain it dry.
There is also an electronic display for MPG, which I have not reset recently, but I have noticed that the number keeps on going down. It used to say 11, now it says 9.9. This has happened over the past month or so. Should I reset it next time I fill up and see what it reads?
Yes. Also consider that the extra ethanol additives they put in winter gas negatively impacts fuel milage as does the typical longer warmup times that engines experience when starting temps are low.. and that can be compounded if you let the vehicle warm up excessively(more than a minute) before driving away.
Old 02-21-2018, 08:52 PM
Im50fast's Avatar
Im50fast
Im50fast is offline
The digital display is measuring based on a certain time period . If you were to get on the highway and go exactly 60 mph, and reset the display, you would see that you are probably actually getting 15miles per gallon on the highway. But if you leave the display running and drive through a 30 minute traffic jam at 5 mph; y will see it drop very very low probably four or 5 miles per gallon. It Calculates the average based on the time period. So it’s very important that you know what the time period is for that calculation.
if you’re getting 10 to 11 miles per gallon, and you are admitting that you do a lot of idling, and I bet you iwould also admit that you don’t get on the highway very much… I suspect your gas mileage calculation is spot on.
Old 02-21-2018, 08:56 PM
abbyC's Avatar
abbyC
abbyC is offline
ok. I am going to hold on this over the next week so I can get you exact answers. Of course, with gas prices the way they are, I can't even get a full tank on the 75.00 limit at my local gas station
Old 02-21-2018, 08:57 PM
abbyC's Avatar
abbyC
abbyC is offline
I live in South Florida, so starting temps are rarely ever particularly low
Old 02-21-2018, 09:22 PM
Im50fast's Avatar
Im50fast
Im50fast is offline
they won’t let you buy $80 of fuel? $85?
anyway, you can do a partial tank.
Fill her up, drive around til it’s down to about a quarter tank, then fill up again. Let’s say you drove 175 miles and refilled with 25gallons.
That means 175 divided by 25 (which equals 7). 7 miles per gallon. I’m making up fake numbers of course. Tell us what you get.
wtroger's Avatar
wtroger
wtroger is offline
Replace the O2 sensors they and the MAF sensor are the main contributor to fuel usage. There are also other sensors that are used but those are the main ones that are used to calculate fuel trim. Get a hand held scanner and see where the o2 sensors are running.
Old 02-22-2018, 07:15 PM
CWR032's Avatar
CWR032
CWR032 is offline
If you want an accurate gas mileage check from a single tank of gas:
Fill it up. Let it click itself off and don't try to add any more. (The limit isn't $75 because you can't buy anymore, it's their pre-approval amount, Just swipe your card again and keep going if you have to)
Either reset the trip odometer or write down the mileage (I always write the current mileage on my receipt)
Drive some, it doesn't have to be the whole tank.
Go back to the same pump at the same station at about the same time of day and fill it again, then do the math. (I use Fuelly.com)
This is how they do the official EPA mileage checks.
Old 02-22-2018, 10:43 PM
GreeVan's Avatar
GreeVan
GreeVan is offline
Miles and year should not be a problem. I bought a 2010 E350 V8, 5.4 (very likely as yours) with 210,000 miles and dumped a lot of money turning it 4x4.
My mileage is 11mpg after the 4x4 and I drive with zero regard for mileage. Your should be 12or higher.
Keep the van, it suits your needs and trading for something else do not warrant any improvement. CHANGE MECHANIC. I do all my work, but $400 for plugs seems excessive and he also seem clueless on what your vehicle need.
Mileage is not great, but these vans are easy and cheap to maintain. Keep it.
Before you change the MAF sensor, try replacing the air filter and while doing it, you will see the MAF and clean it.
Brake dragging or wheel bearing failure could be an issue. After a long drive, place you hand on the middle of the rims and try to feel is one is hotter than the rest. Also, while coasting, roll your window down and listen for some dragging noises. Have one of your kids do the same on the passenger side.
Good luck.
Old 02-22-2018, 11:03 PM
annaleigh's Avatar
annaleigh
annaleigh is offline
A little trick I do when listening for noises sometimes is to roll the windows down and drive beside a building or long wall. 3 or 4 feet away and you can hear sounds you never knew you had. If your back or side windows pop out that will help too. Do it on both sides.
Old 02-24-2018, 11:33 AM
coolfeet's Avatar
coolfeet
coolfeet is offline
I drive an E350 PSD and have gradually replaced many of the aforementioned items.
I replaced tires, ball joints, shocks, radius arm bushings, radiator, brakes, rotors, AC condensor, instrument cluster, batteries, valve covers,...the list goes on.
May seem expensive, but considering how heavy and heavy duty these beast are, these are normal expenses performed every 100k. Now the repairs seem cheap because I will not have to replace these items for a long time. My van has 808,000 miles on it and it drives nice and tight. Diesel fuel is the cheapest expense for this beast. Fuel economy is not much better than the 5.4 or V10. I average 16.5.
When my radiator cracked, I replaced it with an aluminum radiator.
Keep the van. Everything is replaceable. I don't think my van having so many miles is an anomaly. It's an industrial piece of equipment meant to last.
Old 02-24-2018, 09:02 PM
abbyC's Avatar
abbyC
abbyC is offline
Ok. I still have not gotten to the next fill up yet. Does anyone have a mechanic to recommend that is reliable and not terribly expensive here in South Florida? After bringing the van in for clicking on the steering wheel and spending an awful lot on repairs I drove out and noticed a bit later that my steering wheel was still clicking. The mechanic felt really bad about it and told me to bring it back when i can. Really frustrated
Thank you
Old 02-24-2018, 09:16 PM
EagleFreek's Avatar
EagleFreek
EagleFreek is offline
Where in South Florida?
  #28
Old 02-24-2018, 09:47 PM
abbyC's Avatar
abbyC
abbyC is offline
I live in North Miami Beach
  #29
Old 02-24-2018, 11:09 PM
jayro88's Avatar
jayro88
jayro88 is offline
O2 sensors will kill your mileage. Even if they are not quite bad enough to throw a code. Replacing those, cleaning your MAF and checking for any stuck calipers would be where I would start.
  #30
Old 02-25-2018, 12:47 AM
coolfeet's Avatar
coolfeet
coolfeet is offline
Thank you
The clicking sound in my steering wheel was a center link tie rod.
Quick Reply: Fuel economy on '09 e350
