63 Econoline not idling
My 63 starts hard but once it is running the cold idle is good but when it gets warm it will only idle for 2 min before it dies. I have replaced the points and condenser but not adjusted the dwell just yet. Vacuum advance was recently replaced and checked on the distributor, so it does work. The vacuum advance line is an old steel/copper(?) line. My guess is that there may be pin holes in the line? I smell gas after I shut her down and the gas mileage sucks, only getting 13/14 mpg at the moment.
Thanks for the info! Changed the fuel filter but it turns out that the distributor vacuum advance was terrible loose! Tightened it down and timed the engine again but the timing marks are only lining up on #2 cylinder!! I can't seem to get the marks to line up on #1 cylinder .I checked TDC just to make sure and got it close in time and my gas mileage has improved greatly .I am thinking on buying a new distributor . Do you think that will be effective or should I just look at rebuilding the old one? I'm not sure I like the way the vacuum advance keeps coming loose on this one!!
RVF150
06-28-2010 01:48 PM
twinzilla
02-07-2010 09:40 PM
frank83fire
03-20-2009 03:38 PM
7677mess
01-16-2005 09:49 AM
351 power
01-11-2004 10:16 PM
