1993 F250 4x4 Front Leaf Question
Hey guys,
I recently got a 93 F250 4x4 7.3 Turbo and the front leafs are really sagged. It is throwing off the front camber (negative) and giving negative axle sag. I jacked up the front a little and it looks right, while also correcting the camber.
I have a set of stock leafs from a 1979 Ford F250 lying around from a project. I am almost certain they will bolt up, but I'm not sure if this will fix the problem. I would imagine the diesel rated trucks had heavier springs, so I might have the same issue. I also have a 74 F250 'highboy' I can use for parts, the springs are bigger, but I would be worried it would lift it too much. This is a dump run truck, so ride is not important.
Can I use these springs in place of the stock springs?
Would add a leaf be a better option?
Thanks!
Thanks!
Spring rate is very different, on a solid axle truck the same year as the ttb truck springs were 2200 lb, ttb is 3485 lb or so. Best bet would be doing new leaves, 43-498 springs are $120 a side, I put them on mine 2 years ago, still haven't sagged past initial break in, rides decent, and doesn't wear tires bad.
To do super duty springs you will need to do some variation of axle swaps and reverse shackle kits for that to work properly.
__________________
www.ATSsprings.com
Ask About our Ford-Truck Forum Discounts! (1-888-943-8287)
"We sell parts and experience"
www.ATSsprings.com
My father in law has a set of stock leafs, but he's 6 hours away. Worse case I can run the add a leaf to not screw up my new tires and do the other full leafs later. Honestly, I may just check to see if they can correct my camber without doing anything. The lower front doesn't bother me one bit.
This is a dump run truck only. I have a big project going and I am 100% using your train of thought on that. Can't afford to think that way on both. I am running 4" lift SD springs on my 79. 6" lift model correct in the rear.
