Cerma additives
Have any of you ever used this product? They have a very expensive engine additive, along with additives for transmission and fuel system.
https://www.cermastore.com/engine-tr...sel-truck.html
If you want to preserve the engine, fuel system and trans I would suggest the following a: fs2500 oil bypass filter system oil changes every 5K or oil changes every 3.5K miles no bypass filter, you really cannot extend due to fuel in the oil caused by regens in a stock truck unless you delete the DPF which is an entire convo by itself ,use a good synthetic oil like Rotella synthetic 5w-40,this is great oil don't ruin it with snake oil additives, scheduled oil analyst at a company like black stone, I would use opti-lube xpd for a fuel additive to protect the fuel system along with changing the filter every other oil change, I would use a fs2500 by-pass filter on the trans or I would suggest changing/flushing the trans every 15K-20K miles. Motocraft trans oil LV is the best for your trans I would not stray from it or add snake oils to try to improve it. These have worked well for me and are only suggestions. continue your research and you will find what best suits your needs. This is not a cheap plan but its a well thought and throe plan to insure reliability in a much demanding maintained truck.
Also don't let this truck idle, idling a 6.4 is the worst thing you can due and it will take a lot of life out of the engine. The oiling system for the rockers is extremely poor at idle and I feel in my honest opinion is the cause for a lot of the early rocker failure seen in these engines.
cgrandahl64
07-07-2005 08:46 PM
