Best Receiver Hitch for 12 4x4 F150?
I don't know of any ball mount that won't whack you in the shin bone. Why not spend the 30 seconds required to pull the pin and remove the mount when not in use.
https://www.etrailer.com/Ball-Mounts...WTS10047B.html
This is the one I use. It comes in 2 other sizes but I find this covers anything I need.
How high is "pretty high"? How high is the trailer tongue? Will there be multiple trailers involved? In that case you may want to pick a happy medium. The question you ask is rather vague. In general, 3-1/2" is a pretty typical drop for a 12th gen. 4x4. Drop is measured from the top wall of the receiver tube to the upper surface of the ball mount tab. A ball mount with the tab welded flush to the tube is actually a 2" drop.
That really doesn't answer my question, but I'll assume you mean the ball mount that slides into the reciever [sic].
Better aggravation-wise to just leave it in most of the time and remember to make a wide turn when going around the back. Pain is an excellent memory jogger BTW.
I keep the 3-1/2" drop in for the horse trailer. I keep the 2" drop behind the rear seat for the welding trailer.
As stated above, it just depends on the trailer. You can easily measure the amount you need with a tape measure or trial an error at a TSC or similar. The tape measure method is easier.
Connecticut Calvin
02-19-2015 03:14 PM
E40
Other; Brakes, Electrical, Hitches, Weight Distribution & CDL Discussion
01-21-2008 07:08 AM
