Power Stop brakes
#31
I'm not a fan of ceramic brake pads, while the don't fade or ware I have found that they are so hard that they are noisey and it takes more pedal pressure to get them to stop as well as non ceramics.
As far as rotors go I won't run drilled rotors on a towing application as the tend to crack. Slotted rotors are fine except when the need servicing it is harder to turn then, but it can be done. I chose the Raybestos 300 series non directional slotted roters and so far they are my favorite to date. Being a fleet mechanic for 30 years I've changed and turned a lot of rotors.
Mark
Mark
Denny
#32
Mark
#33
The Raybestos Advanced Technology pads are rather good. Hawk Super Duty pads are pretty good in my experience. Running the EBC Yellow Stuff on mine now and the front ones will be gone soon. I thought I could handle the dust from the Yellow Stuff pads but it is to the point they are starting to screw up my wheels from the hard to remove dust.
#34
I HAD the Raybestos R300 on my truck in the front and rear. They were not on too long, shortest time I ever had a set of rotors on my truck. They vibrated under braking and eventually heat checked. It was not a severe vibration but you could tell the slot location was not engineered right and IMO there was too many of the them for the rotor surface area. Better off avoiding them IMO.
Thanks for your help.
Mark
#35
They were on my 04'. Empty weight with me in it is at 7k lbs. Most the truck pulled was grossing around 14,600lbs combined (truck, trailer, load) that was in the mountains but only once a year. Trailer has electric brakes on both axles so it is not like the truck brakes were over worked. Even my 3k lb boat combo has brakes on the trailer. My other boat is under 1k lbs and you really don't know its back there. Obviously the front rotors are a little smaller on the 04' vs the 11'up trucks. Stock 16" wheels with 33" tires. Most of the driving was empty at around 7k lbs mostly back roads on fairly flat ground. I may be harder on brakes than the average truck owner with how the truck gets used but I did not have issues with other rotors like I did with the R300 nor did my dad with his truck which is basically the same and takes the same rotors and pads The rotors just had a weird feel to them under braking which I am sure was caused by the front rotors only. I feel the grooves in the rotor were too plentiful and too close together. I would probably still have the R-300 rotors on the rear if a caliper did not go bad and require new brakes on the rear. The rears did not exhibit any issues I could see otherwise.
#36
Time will tell.
Mark
#37
Okay well I'm already committed so we will see. I already have around 1000 miles on them and the only thing I notice is how much better it stops. Even pulling my 11,800 pound toy hauler they have been flawless and stop with a lot less pedal pressure. I read all the reviews I could find on these rotors and none mentioned cracking. I'm not saying it didn't happen obviously you had some severe issues with them. I wonder why just the fronts cracked and why you could feel the slots.
Time will tell.
Mark
Time will tell.
Mark
So far my plans are to use Preformace Friction pads and new rotors on the front, I'm still leaning towards the Power Stop slotted.
I've used Preformace Friction before with great success in my last DRW. Great stopping power and no fad under heavy mountain braking.
Denny
#38
stay away from Ceramic on your SD.. stick with the semi-metallic.. Ceramics are good for light vehicles.. but on the HD stuff especially with pulling that RV theyll give out on you.. make you feel like you have no brakes at all.. i had Ceramics on mine for about 1000 miles.. after 4 almost accidents from the lack of grip (i seriously thought something else was wrong in the system) on an empty truck, i switched back to Semi-metalics on my 350 and not looked back.. when i was telling the guy at the parts counter my ordeal to buy what i had on the truck prior he said that was why they specifically recommended AGAINST ceramics on HD vehicles..
#39
I'm home and the truck is on jack stands, when I removed the RF pads this is what I found. The shiny spots look like they are solid steel, it appears that the bonding material and the metallic wasn't mixed properly. It's no wonder they squealed The good thing is the rotor has only .001 run out and I'm going to put new Preformace Friction Carbon Metalic pads on the old rotors and hopes for the best, I'm also using a DA with coarse paper to break any glaze on the rotor surface.
Denny
#40
We are back on the road again with the Preformace Friction Carbon Metalic pads and they are well seated in and the rotors cleaned up nicely . I have so much more stopping power with less pressure applied to the pedal that I had to set the gain up on the controller to stop my hitch from clunking when braking caused by not enough trailer braking. They are also silent
Denny
Denny
