6.2L V8 Discuss the 6.2L V8
Power Stop brakes
Old 02-20-2018, 08:07 PM
kry226's Avatar
kry226
kry226 is offline
Let me add that while not on an HD truck, I have had great results with Napa Premium rotors on a light duty truck (about $80 each, but were the most expensive available in the Napa line. Obviously will be more expensive for a Super Duty, if available). Way better than the OEM rotors they replaced.
Old 02-20-2018, 10:14 PM
82_F100_300Six's Avatar
82_F100_300Six
82_F100_300Six is online now
I would use the cheaper brake pads so that they wear instead of the rotor. But buy some wheel cleaner while your at it.
Old 02-21-2018, 09:24 AM
saratoga2011's Avatar
saratoga2011
saratoga2011 is offline
Originally Posted by rvpuller
Yes I will use Rock Auto
Some of you aren't looking at the right front rotors, I have a 13 RWD DRW so the options are reduced with Motocraft $182 each and the Power Stop $142 but the only thing Power Stop shows is drilled and slotted.
Denny
I rechecked and and Power Stop does have a economy for $132
I'm looking at the Power Stop severe duty truck/tow drilled/slotted kit for my 13 also.
Lots of people here saying rotors are cheap do not have a 13 or newer truck with the larger brakes. They are different from the 11-12 trucks.
Old 02-21-2018, 09:44 AM
rvpuller's Avatar
rvpuller
rvpuller is online now
Or they don't have a RWD DRW with that massive hub on the front rotor.
At this point I'm leaning the same way you are for the fronts anyway, the backs depend on what they look like but I'm going to keep on looking
Denny
Old 02-21-2018, 08:15 PM
leadmic's Avatar
leadmic
leadmic is offline
I just did a four wheel brake job on my 2011 F250 cc sb 4X4. I used Bendix fleet pads and Raybestos 300 nondirectional slotted rotors. All I can say is it stops way better than the stock Motorcraft brakes and rotors that came off it. I just got back from the desert and went over the 58 out of Bakersfield through Tehachapi mountains with truck and toy hauler just shy of 20,000lbs. and the brakes were flawless. The truck and trailer stopped better than I have ever had it stop. I am very pleased.
Mark
Old 02-22-2018, 11:49 AM
Turbo Dog's Avatar
Turbo Dog
Turbo Dog is offline
I had Power Stop drilled and slotted rotors with Hawk ceramic pads on my 2013 F150. They were still going strong with 70K miles on them when I traded it in. They improved the braking power year round in all kinds of weather conditions. Only towed about 10% of the time with either a 7K or 4K load.
Old 02-24-2018, 10:08 AM
rsylvstr's Avatar
rsylvstr
rsylvstr is offline
Not a fan of their pads...two sets, standard and the Z36 (or whatever), wore quickly and filled the slots right up, pretty much the material welded right in there.
PowerStop didn't care as I installed them myself and therefor there is no warranty...or customer service for that matter.
Old 02-24-2018, 11:51 AM
J Standard's Avatar
J Standard
J Standard is offline
Originally Posted by kry226
Drilled and slotted means you're losing braking surface too. Not my cup of tea.
But I've never done better than OEM brakes on my trucks. YMMV.
This
Why is this in the 6.2 forum?
Old 02-24-2018, 02:48 PM
rvpuller's Avatar
rvpuller
Thanks for the input guys.
Denny
Old 02-24-2018, 09:12 PM
rkmfordman's Avatar
rkmfordman
rkmfordman is offline
I have used the powerstop on several vehicles and they have been outstanding.got them at rockauto.
Old 02-25-2018, 06:14 AM
rsylvstr's Avatar
rsylvstr
rsylvstr is offline
Guess it depends on the QA that day.
Old 02-25-2018, 09:17 AM
rvpuller's Avatar
rvpuller
Another option I'm looking at are Performance Friction Carbon Metallic pads, i installed them all the way around on my last DRW and they stopped great (way better than OEM) and were still on the truck after 60K miles when I traded but I'm having a hard time finding them for a 2013 DRW RWD.
Denny
  #28
rvpuller's Avatar
rvpuller
Another option I'm looking at are Performance Friction Carbon Metallic pads, i installed them all the way around on my last DRW and they stopped great (way better than OEM) and were still on the truck after 60K miles when I traded but I'm having a hard time finding them for a 2013 DRW RWD.<br /><br />Denny
  #29
Old 02-25-2018, 10:18 AM
rvpuller's Avatar
rvpuller
With my in investigation into slotted rotors I found this and many others like it.
It sounds like unless you in stall them in the right direction they will not clean or cool properly, Power Stop are sold in rights or lefts so they are directional for cooling and self cleaning.
Slotted directional rotors
Denny
  #30
Old 02-25-2018, 04:40 PM
leadmic's Avatar
leadmic
leadmic is offline
I'm not a fan of ceramic brake pads, while they don't fade or ware I have found that they are so hard that they are noisey and it takes more pedal pressure to get them to stop as well as non ceramics.
As far as rotors go I won't run drilled rotors on a towing application as the tend to crack. Slotted rotors are fine except when they need servicing it is harder to turn them, but it can be done. I chose the Raybestos 300 series non directional slotted roters and so far they are my favorite to date. Being a fleet mechanic for 30 years I've changed and turned a lot of rotors.
Mark
Quick Reply: Power Stop brakes
