Oil Light comes on, engine loses all power
Hello there, I have been trying to figure this one out for months with no luck. Now the problem is so bad we can not even drive the car. I have a 2000 ford expedition, 5.4 4wd with 180k miles.
Upon ignition, everything is fine. Once we get into drive and start going it is only a matter a few seconds that the oil light will light up, as soon as it does you can feel all forward pull from the engine stop with a slight jerk. Once this happens the car will shake, the engine sounds muffled, and I can give the engine gas.. as the rpm will go up, but none of that power is felt and the car will eventually coast down to 0 mph.
If I put it in park, and restart the engine it is back to square one. Only a few seconds of driving and it happens all over again. I initially thought it was electrical since the problem could be fixed by just restarting the engine. After reading a lot of forums on here i'm not so sure anymore. I have found a few forums on here that suggest the oil sender unit, or maybe a clogged oil intake hose. Was hoping to find some input from someone with more experience as I, any suggestions?
mjbtn
1997-2006 Expedition & Navigator
07-04-2008 01:22 PM
michaelbarry
General Automotive Discussion
11-17-2005 02:19 PM
firestorm
03-08-2002 08:23 PM
