In need of some knowledge!
I'm seeing an E99 spider there without the AIH and no AIH relay. If a '95 block was used they swapped all your E99 parts over, same if they used an '00 block. As pointed out earlier if it's an earlier block it should have a freeze plug plugging the former fuel pump hole in the top of the block back my the spider. That is not obvious in your pictures.
springtime xmas to me!!!!
only thing underneath not getting changed is rear leaf springs
full Moog suspension kit
full powerstop heavyduty/Tow brake kit
bilstein 5100 shock kit
all new wheel and hub bearings and seals front and back
front leaf springs (upgraded to the 3leaf springs)
all new LED lights all the way around
once all this is done it will be time to order my Riff Raff wishlist
#29
back again guys when I rebuilt the oil cooler and cleaned the block real good I found some more numbers...the serial number I'm seeing is 7.4 JU2U1147088x
can anyone tell me what year block this is...from what I've seen I think its between a E99-2000.5 but I can't find anything definitive
any and all help is appreciated!!!
#30
