2000 f250 V10 Shutter in OD along with bad fuel and oil consumption. - Ford Truck Enthusiasts Forums
Go Back  Ford Truck Enthusiasts Forums > Super Duty/Heavy Duty > 1999 to 2016 Super Duty
Reload this Page >
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 02-18-2018, 10:38 AM
Dyork
Dyork is offline
Dyork is starting off with a positive reputation.
thanks for the add! Newbie here. Iím new to owning the 6.8 but not new to the 2V engine. I bought my truck recently with a blown out spark plug for cheap. It has 238k miles on it and was a fairly easy fix using the calvan parts. Upon repair the truck smoked very badly (white) for a day or so. I noticed after driving it a bit the smoke would stop after the engine warmed up. The truck had been sitting awhile and I figured it had some bad gas so I filled it up with fresh fuel and continued to drive it hoping all of the shuttering and smoking symptoms would eventually cease. I figured this truck was not taken care of and probably just needed plugs and coils. I changed those and it didnít seem to help much. I did the engine carbon clean spray and that did make some difference. I am going to do it again today. My main concern is the oil consumption. I changed the pcv but it didnít seem to make much difference. Right now it looks like Iíve got 1/4 tank left and my odometer says Iíve only driven 172 miles on this tank of fuel. Would carbon buildup cause the smoke and oil use if a valve is really really dirty? Anyone have anything else to suggest? I think my truck is a without ego but will check again. Thanks so much to all of you guys who have been posting here and other places for all these years. Much appreciated.
Old 02-18-2018, 10:58 AM
timjimmy
timjimmy is offline
timjimmy is starting off with a positive reputation.
I would suggest renting a compression tester and testing all the cylinders. Worn cylinders and piston rings can cause oil to leak into cylinders and burn, as well as a lose of adequate compression would make the truck run like crap. You should be able to get a loaner kit from most auto parts stores and get a full refund when you return it. That would be a good start.
If it reacted well to some engine cleaning, but two cans of Seafoam. Dump one in the fuel tank before filling up. Get the engine nice and hot then take the other can and unplug the vacuum hose that runs from the intake to the brake booster. Leave the hose plugged into the intake, and take the brake booster side of the hose and place it into the second can of Seafoam while the engine is running. It will shudder, sputter and want to die, but vacuum up the can of fluid as fast as the engine will accept it without dying. As soon as the can is empty, shut the engine off. Let it sit for about 20 minutes for the cleaner to penetrate and break up oil and varnish deposits, then drive it like you stole it. It will initially smoke like crazy, but that's the best way that I've found to clean out an upper engine. I don't like using the method of spraying cleaner into the engine because it takes too long for the can to get sprayed into the engine that most of it gets burned up and isn't able to soak into the engine. I'm not very familiar with the vacuum lines on that particular engine, but the closer you can get a vacuum line to the air filter, the better. Ideally, you use a vacuum line that is upstream of the throttle body so it can get distributed to the entire engine.
Old 02-18-2018, 04:46 PM
4XBuilder
4XBuilder is offline
4XBuilder is starting off with a positive reputation.
My 2001 f-250 V10 had a similar condition. I changed the plugs, coils, air filter, and did the seam foam/steam treatment and it smoothed right up.
Old 02-18-2018, 08:28 PM
Djosbun
Djosbun is offline
Djosbun is starting off with a positive reputation.
I would bet that you have multiple cylinders with low compression. Every one of your symptoms points to this.
ó Dave
Old 02-23-2018, 03:32 PM
Dyork
Dyork is offline
Well I finally got a break in the weather to try the seafoam. It smoked really hard for about a mile then cleared up. It didnít seem to help much. I have noticed it does get better with octane boost or fuel injector cleaner but when I fill it with pure gas it runs rougher. I cleaned the maf while I was in there. I have a compression tester but I didnít use it when I was putting plugs in because it pulls hard and runs pretty well otherwise. I will add I did a spark plug Re thread when I first got the vehicle
Old 02-25-2018, 12:14 AM
Dyork
Dyork is offline
UPDATE
I tested all the cylinders that had random misfires and they all came back around 125-150ish. Iíve heard of intake manifolds leaking Iím going to check there tomorrow.
Old 03-08-2018, 10:32 PM
Bsider5t8
Bsider5t8 is offline
Bsider5t8 is starting off with a positive reputation.
Keep me up-to-date as my 99 has the same issues and will pass along any thing l have for you...As for the sea foam on the back of the throttle body there is a vacume hose that works wonders
Old 03-09-2018, 02:16 AM
Evan_P's Avatar
Evan_P
Evan_P is offline
Evan_P is a splendid one to beholdEvan_P is a splendid one to beholdEvan_P is a splendid one to beholdEvan_P is a splendid one to beholdEvan_P is a splendid one to beholdEvan_P is a splendid one to beholdEvan_P is a splendid one to behold
You want to test ALL cylinders and see how much they vary in compression.
Old 03-10-2018, 05:31 PM
SDSC4X4
SDSC4X4 is offline
SDSC4X4 is starting off with a positive reputation.
White smoke usually indicates coolant leaking into a cylinder. Have you added coolant? Usually a bad head gasket if these engines do it. but could be getting into #1 oe #6 cylinders from the front coolant crossover on the lower intake.
unclelee
30
04-26-2015 04:40 PM
JoeFin
13
12-26-2011 10:13 PM
ssjrsw
Flatbed, Car, Boat, Utility, Horse & Misc. Trailer Towing
07-13-2011 04:33 PM
gofish
23
01-25-2010 08:13 PM
sharkwhit
Modular V10 (6.8l)
18
10-11-2004 10:36 AM
Quick Reply: 2000 f250 V10 Shutter in OD along with bad fuel and oil consumption.
Contact Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2018 MH Sub I, LLC dba Internet Brands
