The 240 Died a Violent Death Coming Home from Work Today
#61
#62
It's good that you got the pipes and a bit of advice for anyone going with the efi manifolds, those flanges are hard to find by themselves. I did efi manifolds a few years back and just took the truck to my small town muffler shop, they couldn't find the flanges nor could any of the 3 local parts stores. I had one and had to make the other one from a 5.8 flange.
#63
#64
#65
Good news. I bet that bad boy will be running by the time I jump back in the Kingdom Monday morning.
#66
Took a break to eat a bite .....it was the best pizza on the block.
#71
The rotating assembly is in the engine, head is installed and valve adjustment has been set. Most of my time has been consumed cleaning, bead blasting, priming and waiting for paint to dry on parts and pieces.
These are only some of the parts that have been cleaned up.
The original exhaust manifold is done for. I mocked up the intake and the EFI exhaust manifolds to try and figure out what I need to do in fabricating a coolant plate for the underside of the intake.
#73
Man, that's looking purty! Are you using a gasket for the EFI exhaust manifolds? I thought I read that they're supposed to go straight on the block, or they could crack. I'd sure love to go from the likely 240 in my truck, to a real 300 with the EFI exhaust manifolds.
Probably going to make a road trip (by car) to buy a new transmission for my rig on Tuesday, so I'll ask if he's got any 300s, and if so, maybe go back with the truck back there once the transmission is in.
#74
#75
