Cost to retrofit OEM LED headlights on '17 F350 SD?
With that being said, you`re out of pocket cost plus labor will fall in the 2,500-3,500 range.
Not worth it. Got them on the wife’s flex, one Bank of LEDS burnt out. Ford would not replace them under extended warranty. Apparently LEDS are not covered, same goes for your other bulbs. No way to fix, only replace the whole light which was 800$ or something rediculous . That’s the reason I opted for non LEDs on my Super Duty.
I was just curious anyway, I'd never order. My one and only HID experience sucked and I'm in no hurry to try again.
I agree. I absolutely love my F350 but the lights are an epic fail. Epic. Plus I am always getting flashed when I am on low beams! What is up with that? Checked the pattern and it looks correct up against a wall.
I think it has alot more to do with the fact that all 4 lights are on regardless of high or low beam. I have been tempted to flash myself then remember all 4 lights are on. Plus the fact the housing is massive I think gives others a false assumption.
I’m setting the bar low with those Anzo. Hopefully I’ll be impressed with quality. I’d be willing to upgrade low/hi beam with bi xenon units.
But i do have questions. And no where can I find answers.
They are plug and play for halogen headlight trucks.
How are they dealing with the DRLs that we see in the videos. These lights have DRLs, blinkers and halogens projectors. I can see some Forscan work needed. To moved DRLs from headlights to fog lights or position/blinkers. I’m in Canada so I know those issues will have to dealt with.
Just cant justify 2500-3000 for OEM led headlight
