wiper motor "park" -- help?
On my Cherokee motor the gray wire is park. The signal comes off of the low speed terminal (White) to momentary switch, to park (Gray).
Not sure if this is the way to go, but it works.
So you have to use a momentary switch to make park? If that is the case that explains why I did it wrong, I thought you sent power to the park wire full time. Maybe a wiper switch with a momentary "wiper wash" switch would work.
Yes, with the switch I used, an inexpensive one I got On ebay, the park would not work. I already had the starter switch in the dash unused because I went with the '56 switch with the built in start position. So it is a bit odd but the start switch wired in between the slow speed and the park works.
FWIW, I was finally able to figure it out so that my 2 speed switch works with proper park when 'off'... now the problem is the d@mn linkage; realized after spending too much time and effort that I would be having the wipers park on the wrong side ().
I'll follow up this weekend with the correct wiring for those interested. Back to the drawing board on the linkage mods...
A link to an old thread that helps with the same old problem.
https://www.ford-trucks.com/forums/1...-question.html
I have some photos of my Jeep motor setup in my photo album
https://www.ford-trucks.com/g/album/908768
https://www.ford-trucks.com/g/picture/908778
I used the wiper switch out of an late 60s Ford truck I can't find my wiring diagram.
sure wish the 52 linkage was as straightforward as your 54!
82f100460
04-01-2012 03:30 PM
dan66tampa
07-29-2005 08:43 AM
ford55truck
10-28-2004 11:20 PM
