2015 + Expedition & Navigator 2015 + Ford Expedition and Lincoln Navigator
Removal of Dealer Decal on Painted Tailgate
Old 02-14-2018, 08:43 AM
ranger pat's Avatar
ranger pat
ranger pat is offline
I was so excited to take delivery on my 2018 in December that I did not even notice the dealership decal on the tailgate. Once the weather warms up a bit, I plan to remove it. What is the best solvent or method to make the decal go away?
Old 02-14-2018, 09:41 AM
dennis48755's Avatar
dennis48755
dennis48755 is offline
Same here.
Also removing the license plate frame.
Use a hair dryer, the heat will loosen the adhesive. Worked good for me with my previous Expedition.
Dennis
Old 02-14-2018, 10:02 AM
ranger pat's Avatar
ranger pat
Thanks, I will try a heat gun on the low setting this weekend.
Old 02-14-2018, 01:50 PM
johnkn's Avatar
johnkn
johnkn is offline
and WD40 or Goof Off will remove the residual adhesive. Then clean with Windex.
Old 02-14-2018, 05:23 PM
YoGeorge's Avatar
YoGeorge
YoGeorge is offline
WD40 and Goof Off are petroleum distillates with oil in them (and orange flavor in the case of goof off), so you could use mineral spirits, lighter fluid, or some other low-strength solvent for any residual adhesive. Lighter fluid (naphtha) is particularly gentle on lacquer and other paints. Watch the heat gun so as not to burn off paint.
Old 02-14-2018, 09:40 PM
FORD COASTIE's Avatar
FORD COASTIE
FORD COASTIE is offline
Supporter of Patriotism
Received 2,363 Likes on 1,709 Posts
I have used Kent Automotive brand Acrysol to remove glue, tar, and tree sap from my vehicles. It works good and doesn't damage the paint. It's commonly used on body shops.
Old 02-15-2018, 07:52 AM
alloro's Avatar
alloro
alloro is offline
Received 4,194 Likes on 2,430 Posts
Easy Off oven cleaner. Spray it on, let it sit for about 10 minutes and wipe it off. I used it to remove lettering on the side of my van from when I bought it, does not damage the paint.
Old 02-15-2018, 09:37 AM
YoGeorge's Avatar
YoGeorge
YoGeorge is offline
Yikes....the way that stuff cuts through grease, it will definitely pull wax off your car paint and may even pull some of the plasticizers out of the clear coat. It is caustic as hell and I've heard of shops using it to remove painted pinstripes and painted logos from cars. It WILL etch the clear coat.
I would use a product designed for automotive paint. Many of the suggestions above are fine--tar and grease removers designed for auto paint are not gonna hurt the finish.
Old 02-16-2018, 09:42 AM
alloro's Avatar
alloro
alloro is offline
No it doesn't. Like I said, I've used it so I know for a fact it does not hurt the paint.
Old 02-16-2018, 11:08 AM
YoGeorge's Avatar
YoGeorge
YoGeorge is offline
Good for you. I would use a product designed for the purpose on a BRAND NEW TRUCK.
Easy Off is massively caustic and current water-borne paints are fragile. If you used it on an old second hand van that you bought cheap, that is not the same as using it on a brand new truck made of aluminum and using modern paint.
All you know is that it did not appear to visibly damage *your* paint on *your* old truck. But etching clear coat may take years to show damage.
Old 02-17-2018, 11:41 AM
Going_Going_Gone's Avatar
Going_Going_Gone
Going_Going_Gone is offline
Just be careful using a heat gun. Those get way hotter than a blow dryer and it doesn't take much to soften the adhesive, particularly on a newly applied sticker.
Old 02-17-2018, 05:01 PM
dennis48755
I removed my dealers decals yesterday using a hair dryer, with just a light application of heat, they practically fell off leaving no residue. But I finished up with Windex anyway.
Dennis
Old 02-18-2018, 09:22 AM
DoubleJ73's Avatar
DoubleJ73
DoubleJ73 is offline
If I can add one thing to everyone's ideas above.....PATIENCE!
I did mine with a heat gun on low....little bit at a time...followed by WD-40, then windex. Worked fine.
Old 02-19-2018, 06:07 PM
ad2435's Avatar
ad2435
ad2435 is offline
Just tell the dealer to take off their advertising.
When I order a new vehicle, I tell them not to put their dealer info on the vehicle when it comes in.
When I buy one off the lot, I tell them to take their dealer info off of the vehicle.
I tell them to do this before I sign any paperwork.
They have no problem taking it off for me.
Why go through all the above hassle??? It doesn't make sense.
Old 05-13-2018, 10:18 PM
EXPE15's Avatar
EXPE15
EXPE15 is offline
I had one I had to remove but for the most part a lot of dealers at leat in my areas have gone to license plate frames which are much easier to remove. With mine I did a sharp new razor blade and removed very carefully.
Quick Reply: Removal of Dealer Decal on Painted Tailgate
