Seat upholstery experts?
Old 03-04-2018, 10:16 AM
ExxWhy's Avatar
ExxWhy
ExxWhy is offline
Received 2,109 Likes on 560 Posts
I took the fabric off my seats to clean. Replaced the seat cushion foam. Put it back together and it's not lining up right. Fabric isn't moving with it assembled, tried to adjust it. Seems like the lines are where they should be based on the creases in the foam. Is it possible the top cushion is misshaped compared to the new cushion on the bottom? Or did I just make a rookie mistake putting them on? Can I fix it with the seat apart again? Does it matter?
Old 03-04-2018, 11:07 AM
Jeff53's Avatar
Jeff53
Jeff53 is offline
It looks to me like the fabric is installed correctly, but the seat back was not reinstalled correctly. Looking at the picture, it appears that the seat back needs to go more to the left, or towards the center of the car when the seat is installed, in relation to the seat bottom.
"I took the fabric off my seats to clean. Replaced the seat cushion foam. Put it back together and it's not lining up right. Fabric isn't moving with it assembled, tried to adjust it. Seems like the lines are where they should be based on the creases in the foam. Is it possible the top cushion is misshaped compared to the new cushion on the bottom? Or did I just make a rookie mistake putting them on? Can I fix it with the seat apart again? Does it matter?"
Old 03-04-2018, 05:56 PM
ExxWhy's Avatar
ExxWhy
ExxWhy is offline
I believe I managed to answer my own questions today. It appears on closer inspection the foam is just sagging to the side compared to the passenger seat. Kinda like the bottom was. Tried to adjust the cover on the other seat that is still apart, and it only fits into the velcro one way. Does it matter? Not really since I will never look at the driver's seat from straight on. From the side, it looks fine. Really happy with how they came out, 18 years of abuse mostly washed away. Plus they smell like Tide instead of old truck.
I did double check the attachment, it fits in a pin on one side only one way with 2 bolts on the other. Fairly idiot proof.
Old 03-04-2018, 07:25 PM
sddesigns's Avatar
sddesigns
sddesigns is offline
Still looks great, love the smell of TIDE in the morning!
jdscooby
13
07-21-2021 10:35 AM
sdsurf3573
05-27-2016 07:29 PM
rtcalabrojr
28
01-14-2012 10:54 PM
NBC-Steve
38
08-20-2011 05:19 PM
Quick Reply: Seat upholstery experts?
