What is the difference between a 8BA and a 8RT flathead V8 - Ford Truck Enthusiasts Forums
Go Back  Ford Truck Enthusiasts Forums > Older, Classic & Antique Trucks > 1948 - 1956 F1, F100 & Larger F-Series Trucks
Reload this Page >
Old 02-13-2018, 07:48 PM
50trucking's Avatar
50trucking
50trucking is offline
50trucking is starting off with a positive reputation.
I have a 8RT that has just been rebuilt in a 1952 Ford F1 and found that the block is cracked at the top of the valley, behind # 1 valve springs level with the valve guides. I didn't discover the crack until I put water in the radiator in preparation to crank it and noticed water in the oil.
I guess I will have to find another block.
Can anyone tell me what blocks will work with my 8RT? A 8BA looks the same but I am not sure. What are the years I can use and what are the differences?
Old 02-13-2018, 07:52 PM
ALBUQ F-1's Avatar
ALBUQ F-1
ALBUQ F-1 is online now
ALBUQ F-1 has a superb reputationALBUQ F-1 has a superb reputationALBUQ F-1 has a superb reputationALBUQ F-1 has a superb reputationALBUQ F-1 has a superb reputationALBUQ F-1 has a superb reputationALBUQ F-1 has a superb reputationALBUQ F-1 has a superb reputationALBUQ F-1 has a superb reputationALBUQ F-1 has a superb reputationALBUQ F-1 has a superb reputation
Any flat V8 from '48 to '53 will work, but you want to stick with engines that use the wide belts. Car engines after (I believe) '51 used narrow belts. You can use the block from a Car engine, just swap the pulley and water pumps from your old engine.
One caveat; Cars in '48 still used the older style V8, you don't want that. Trucks got the newer 8BA-style engines first (in '48), then in '49 all used the newer style engine.
Old 02-13-2018, 07:56 PM
Flat Ernie
Flat Ernie is offline
Flat Ernie is gaining momentum as a positive member of FTE.
I'm pretty sure your 8RT has some of the lowest compression heads. If you find an 8BA, use it.
Pulleys, water pumps, and fans/generators can generally be swapped to address the belt issue(s).
55 f350
Flathead V8 & Flathead 6
12-03-2007 09:57 PM
ricksta56
13
11-11-2007 07:31 AM
soule46
1947 and Older Ford Trucks
10-19-2006 11:14 AM
Narwhal
01-04-2006 01:19 AM
loudfords
08-23-2004 04:32 PM
Quick Reply: What is the difference between a 8BA and a 8RT flathead V8
Contact Us About Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2018 MH Sub I, LLC dba Internet Brands
