breather hole in head ? 60 292 - Ford Truck Enthusiasts Forums
Old 02-13-2018, 04:08 PM
mad murdock's Avatar
mad murdock
mad murdock is offline
mad murdock is starting off with a positive reputation.
trying to get my 60 F-100 w/292 running... the older ford motors are not what I'm familiar with... so I'm putting the carb back on, and notice a hole in the drivers side head toward the rear, near where the manifold bolts down, that looks like a breather hole ??
totally at a lose at this point....
I got the truck with the motor and trans in the bed.... not together.
anyone give me a clue would appreciate it
Old 02-14-2018, 06:37 AM
willowbilly3
willowbilly3 is offline
willowbilly3 is a name known to allwillowbilly3 is a name known to allwillowbilly3 is a name known to allwillowbilly3 is a name known to allwillowbilly3 is a name known to allwillowbilly3 is a name known to all
A picture would be helpful but no breather in the head that I know of.
Old 02-14-2018, 10:09 AM
hiball3985's Avatar
hiball3985
hiball3985 is offline
hiball3985 is gaining momentum as a positive member of FTE.hiball3985 is gaining momentum as a positive member of FTE.
If it's for the Drivers side you may be missing the insert for the temp sending unit. Passenger side will have a freeze plug. The insert presses in and is available from after market suppliers.
Old 02-14-2018, 11:13 AM
Tedster9's Avatar
Tedster9
Tedster9 is offline
Tedster9 has a superb reputationTedster9 has a superb reputationTedster9 has a superb reputationTedster9 has a superb reputationTedster9 has a superb reputationTedster9 has a superb reputationTedster9 has a superb reputationTedster9 has a superb reputationTedster9 has a superb reputationTedster9 has a superb reputationTedster9 has a superb reputation
Intake manifold bolts
When installing the intake manifold be certain not to use excessive length bolts. The intake manifold bolt holes in the head intersect the push rod passages and too long a bolt can hit the push rods. Also be certain that the bolt holes in the heads at the rear of the manifold are plugged These are the threaded holes that are unused but are drilled through into the push rod passage. Water, dirt and other crud can enter the engine through these holes. Be sure to use short bolts, about " of thread so you don't hit the push rods.
http://ford-y-block.com/assemblyerrors.htm
Old 02-15-2018, 12:37 PM
mad murdock
Awesome..... thank you. that makes perfect sense... temp. sending unit. these older fords are teaching me a lot of things.
Thank you for your help
Old 02-15-2018, 12:46 PM
mad murdock
Y
I have already run into bolt problems.... thank you for the extra info. turns out one of the manifold ears has been welded back on and ground... but the work wasn't so good thanks
Old 02-15-2018, 12:50 PM
mad murdock
photo of hole in head
CraigerF100
16
09-13-2017 09:10 PM
AbandonedBronco
05-12-2017 05:03 PM
bjmayberry2
27
08-30-2016 05:48 PM
hdshadpar
1961 - 1963 F100 Unibody
06-03-2016 07:04 AM
Aaron-71
27
03-21-2016 10:53 AM
Quick Reply: breather hole in head ? 60 292
Contact Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
