another 460 swap, what transmission? - Ford Truck Enthusiasts Forums
Go Back  Ford Truck Enthusiasts Forums > Bronco > 1978 - 1996 Big Bronco
Reload this Page >
Old 02-13-2018, 01:48 AM
78Broncoinpieces
78Broncoinpieces is offline
78Broncoinpieces is starting off with a positive reputation.
poked around a bit and didn't find a good answer.
78 Bronco, what are the transmission options?
its a ground up build so anything goes, either auto or manual.
currently has a C6, (actually it's laying on the garage floor next to it)
I know a NP435 or T18 would fit, but I'm looking for overdrive.
any factory 5 speed manuals that will fit between a 460 and NP203?
any factory autos with overdrive and lockup TC that won't need a computer?
are there any charts showing the OD gear ratios so I can determine what axle ratios to get my cruising RPMs? I know the math, just need the tranny numbers.
thanks
Old 02-13-2018, 01:29 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Mark Kovalsky is offline
Mark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputation
Not that will fit a 460.
Old 02-14-2018, 01:23 PM
Kemicalburns's Avatar
Kemicalburns
Kemicalburns is offline
Kemicalburns has a great reputation on FTE.Kemicalburns has a great reputation on FTE.Kemicalburns has a great reputation on FTE.Kemicalburns has a great reputation on FTE.
you could have an AOD built to handle the power and isnt much more than having a C6 built. for a manual trans i would go with a ZF 5 speed.
an E4OD would work well, just run a Bauman trans controller and get a tone ring mounted to the back of the tcase.
twtomt15
04-30-2016 12:18 AM
TheMechanicalAnimal
WTB - Parts & other
08-13-2012 11:26 PM
Beast12
01-01-2007 02:31 PM
Umpqua Arms
11-24-2002 03:40 PM
Quick Reply: another 460 swap, what transmission?
Contact Us About Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2018 MH Sub I, LLC dba Internet Brands
