estimated curb weight of a 1973 SC with cummins swap
hey guys, trying to figure out how much a 1973 F250 SC 4x4 with a cummins 12 valve weighs. vehicle is not running and needs to be towed. Im trying to figure out if I can rent a Uhaul car trailer and tow it home. tow rig is not an issue, more concerned about the weight of the truck while on the rental trailer.
No matter the year I bet that SC long bed will not fit wheel base length wise on that U haul car hauler trailer...and I am sure it is WAY over the weight rating on that trailer.
https://www.uhaul.com/Trailers/Auto-...ort-Rental/AT/ Capacity: Max load: 5,290 lbs. Gross vehicle weight: 7,500 lbs. max. Empty weight: 2,210 lbs. Actual deck length is 148".
A 4wd reg cab LB will barely, and I mean BARELY fit on a u haul car hauler with stock tires. I use to have a pic to prove it.. But exceeds the Max Load weight.
And if you tell the u-haul folks what you are going to put or try to put on it and the computer says NO, I bet they will not rent it to you.
And if you tell them you are hauling a 99 Ford Ranger and then put what ever on it and have an accident or the trailer breaks and it is not what you said you were going to put on it....oh boy hang on to your tail, u haul could charge you for repairs or even a new trailer.
Hesson81
Fifth Wheel & Gooseneck RV Towing
05-01-2019 10:46 AM
