Rear most valve cover bolts - best technique?
Did my passenger side UVCH and glow plugs Saturday, then started on drivers side when I noticed two of the oil deflector shields and bolts were completely detached and laying next to the rocker arms. Counted my lucky stars.
Now I have doubts about the passenger side oil deflector shield bolts, and have to pull the cover back off to check.
I have the 13mm short form universal socket that everyone recommended and it's really the only thing I could get on a some of the valve cover bolts. The rear most drivers side was especially hard to get to for some reason. I fidgeted with that one for 10 minutes before finally getting traction.
Is there a "best technique" for getting a socket on those rear most valve cover bolts that we can't see with our eyes? Is coming in from the bottom or maybe the wheel well any better?
Passenger side lower bolts I do through the wheelwell.
Motor was cold when I did the work so I did not torque hold down bolts.
The second link also lists the valve cover torque as 97 INCH pounds
Engine can be cold to torque the injector hold down bolts. Then you reconnect the 42 pin, leave the valve covers and ic piping off and let it idle for 30-40 minutes to get the engine up to operating temp, then retorque injectors. That's what is termed a hot torque on here.
Injector hold down spec is 120 INCH pounds, but most go 130, engine runs much quieter if you do
Scotttahoe tried that, and profoundly regretted it the next time he went in. It was far easier to "target" a bolt with a 13mm flex socket than it was to nail that dink of an Allen hole with the correct orientation. He and I spent more time extracting the Allen bolts than we did for the entire removal and installation of the normal bolts on Stinky's valve covers.
As for the rear bolts on the valve covers (torque values aside), face the windshield and use your arm nearest the engine to position the socket. Use your other hand to use the tool at the end of a stupid-long extension. I have about 18" of extensions, a cordless drill, and a universal joint. I get those bolts out in less than 10 seconds.
How I approached the driver side was to get a thick comforter (I have an old one I keep in my shop) and lay stomach down on top of the engine. It helps to have a concrete block or something to stand on to help yourself up.
I used my left hand, snaking under the master cylinder & behind the wire looms, to reach the back of the valve cover and hold the socket in place. Used right hand to loosen/tighten. Hard to get a usable torque measurement with universal joints in the mix.
For the very back bolts (one on each head), I use a 13mm deep with a universal - the same one I use on the 13mm stud bolts. With the deep and universal, it gets up and clear of the valve cover - then it's just some long extensions to get to the cordless impact driver in my other hand. I have a Milwaukee Fuel 18V impact driver, which has the ability to set the torque with control buttons. I set the torque that has never come loose (without bending stuff), and pull the trigger. I used to use a Milwaukee drill (pre-Fuel) with torque setting on the head, so that will work as well.
I've tightened the valve covers by hand and by driver a gajillion times, and I've never had one of those come loose. Now as far as the injector hold-down bolts....
Is blue loctite a good bet for the hold down bolts? I'm thinking I should pull my drivers valve cover back off and check them. Haven't connected the CAC or airbox hoses up yet.
Pulled both my covers again tonight to prepare for hot torque of rocker bolts.
That drivers side rear bolt is definitely the PITA of them all. Had to use my 13mm stubby universal to pop it loose.
Discovered that I could use a straight 13mm deep well and a 3in extension for the passenger side rear bolt.
Unfortunately I had to stop because the air inlet tube had major cracking. Ordered a replacement Ford part off Amazon for $48.
Here are the bolts that need to be checked/torqued when the engine is hot:
Ref: https://www.ford-trucks.com/forums/7...ml#post6785635
Also a good thread with discussion about hot torquing these bolts
https://www.ford-trucks.com/forums/1...wn-torque.html
The items circled in red are the rocker arm pedestal bolts (20 lb-ft). The bolt circled in blue is your injector hold down bolt (120 lb-in). This picture just happens to be of the #4 with the circles on it.
on
This is my setup for all the valve cover bolts. I use a battery ratchet from HF.
More details here:
https://www.ford-trucks.com/forums/1...l#post17765875
More details here:
