Grille and Brush Guards available for our Trucks
Old 02-14-2018, 07:36 AM
Olds64's Avatar
Olds64
Olds64 is offline
Olds64 is starting off with a positive reputation.
OHHH YEAHHH (glad you threw in the pic of the Dentside)!
Old 02-14-2018, 08:14 AM
SCFlareside's Avatar
SCFlareside
SCFlareside is offline
SCFlareside has a great reputation on FTE.SCFlareside has a great reputation on FTE.SCFlareside has a great reputation on FTE.SCFlareside has a great reputation on FTE.SCFlareside has a great reputation on FTE.
Shipping
Just a quick note on shipping: it will vary by area of the country and size / weight. One member got a quote on the basic grille guard and shipping was $90.00 to the northeast (From the shop in Florida). That's not too bad - total cost shipped is close to $350.00.
It's another story if you are doing the full grille / brush guard, shipping quote was substantially more - so, do be prepared for that.
Old 02-16-2018, 11:54 PM
4x484150's Avatar
4x484150
4x484150 is offline
4x484150 has a good reputation on FTE.4x484150 has a good reputation on FTE.4x484150 has a good reputation on FTE.
SC, thanks so much for posting this, and for getting the ball rolling on getting these made! I need to spread the lovins around, but reps to you for this thread!
Old 02-20-2018, 03:20 PM
reamer's Avatar
reamer
reamer is offline
reamer has a great reputation on FTE.reamer has a great reputation on FTE.reamer has a great reputation on FTE.reamer has a great reputation on FTE.
Now 2 sources, Sterling Equipment and, Me.
I can ship it un assembled, with or without the third smaller top bar....
Guard without top bar.
With top bar.
Without
With
Old 02-20-2018, 11:06 PM
SCFlareside
REAMER That is awesome! Looks really good, nice idea with the smaller top bar also!
Old 06-07-2018, 01:58 PM
jcrogers
jcrogers is offline
jcrogers is starting off with a positive reputation.
Reamer,
Thanks for the info. Just got an email back from Wade at Sterling, he thought I wanted a roll bar. Asked him about a Chrome Brush/Grill Guard for my 86 Flareside so that I could keep the original chrome bumper. Will let you know what he says.
Old 06-10-2018, 06:48 PM
reamer's Avatar
reamer
reamer is offline
Interesting if he does Chrome...
Old 06-13-2018, 07:45 AM
jcrogers
jcrogers is offline
Reamer, you were right, no chrome. Here is what Wade sent:
Sorry, No chrome plated product – only powder coated steel.- For the 1980-1986 F150 the guards bolted to the exposed carriage bolts that attached the bumper to the frame. - At that time, we adjusted the overall width of the central grill guard to be to the outside OR inside of the carriage bolt centerlines – depending on customer request. Many customers liked the narrow look – and just as many liked the wide spec.- The wide spec was used with the brush guards. Below is the Traditional Grill Brush Guard styling we made in the early 80’s – Part# 84C-T @ $400.00 + shipping
- However, a narrow spec can also be created
The pricing is based on the final configuration + the shipping cost
GRILLE & BRUSH GUARDSTECHNICAL INFORMATION:- All Grille & Brush Guards are constructed to order for the specific vehicle. Made In The USA!- Full 5/16” Mild Steel Side Plates – Laser Cut- Grill Guard Tubes: 2 1/4"od x .083" Wall Mild Steel Tubing- Brush Guard Hoops - Wrap-Around Style & Flat Style: 1 1/4"od x .083" Wall Mild Steel Tubing
- One-Piece Fully MIG Welded Construction
- 2 Auxiliary Light Mount Points (Additional Mount Points Available At Time Of Order)
- Powder Coated Finish - Semi-Gloss Black (Sorry, NO CHROME/STAINLESS/ALUMINUM)- Complete Installation Hardware And Instructions
GUARD MODELS:
Gator Model Brush Guard / Grill Guard-- Part# XX..-G @ $525.00 + Freight (Traditional Model Brush Guard / Grill Guard below plus Gator Option, Jammer Option, 3rd Bar Option, Euro or 2” over-rider Option, and Wires Option listed below)
Traditional Model Brush Guard / Grill Guard-- Part# XX..-T @ $400.00 + Freight (Base Model Grill Guard below with integrated Traditional Non-Wrap Style Brush Guard Hoops)[img]
Base Model Grill Guard -- Part# XX..-B @ $300.00 + Freight (Two steel side plates, three cross tubes, and two auxiliary light mount points)
OPTIONS:
-G: 2"OD round tube brush guard hoops. Option for Traditional Model Package only @ + $45.00.
- To order add "-G" suffix to part #
-W: for combination grill guard & brush guard models only. Horizontal 3/8" wire rod screen in brush guard hoops (wrap-around and flat style brush guard hoops) @ + $105.00
- to order add "-W" suffix to combo part #
-B : third across tube added at base of guard @ + $32.50. - to order add "-B" suffix to part #
-J: 1 1/2" wide steel backbone added to steel side plate edge with full length vinyl overlay pad. @ + $85.00
- to order add "-J" suffix to part #
-E : 1.25” hood bar on top of guard only or span between brush guard hoops on brush guard models @ + $37.50.
- to order add "-E" suffix to part #
-S : 2" tube over-rider Bar (center hood bar) on top of guard @ + $42.50.
- to order add "-S" suffix to part #
-AR : WP Option -- 2" box receiver mount added to bottom of winch cradle. @ + $65.00.
- to order add "-AR" suffix to part #
-L : WP Option -- Light bar cross bar for mounting 4 auxiliary light mount points just above winch. Drilling required. @ + $90.00
- to order add "-L" suffix to part #
-WP: Add low-profile mount series 3/8” steel cradle for mounting all low-profile mount winches. @ + $125.00 - to order add “WP” to part number – example: XX..WP-B for Base Model configuration-WP16: Add upright heavy duty series 3/8” steel cradle for mounting Warn 8274, M12000, M15000, and 16.5ti Winches. @ + $180.00 - to order add “WP16” to part number – example: XX..WP16-B for Base Model configuration-MT: Add 2” receiver multi-mount (winch and winch cradle not included). @ + $125.00 - to order add “MT” in part number – example: XX..MT-B for Base Model configuration
Wade P. Rogers
Sterling Equipment & Mfg. Co. Of Central Florida, Inc.
803 Line St.
Umatilla, FL 32784
Ph: (352) 669-3255
Fx: (352-669-7711
Email: [email protected]
Web: www.sterling-equipment.com
Old 07-18-2018, 11:16 AM
malachy's Avatar
malachy
malachy is offline
malachy is starting off with a positive reputation.
Has anyone placed an order from Sterling recently who can attest to the price? I contacted them today looking for a quote on the basic, two bar grill guard and was quoted at over $500 without shipping, double what SCFlareside was told. I can understand a price change, but for it to double in the course of a month seems extreme.
Old 07-25-2018, 08:33 AM
flappy188's Avatar
flappy188
flappy188 is offline
flappy188 is starting off with a positive reputation.
any1 know about this?
i need a brush guard like the white one above for my 74
Old 07-25-2018, 05:02 PM
ctubutis's Avatar
ctubutis
ctubutis is offline
ctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputation
I won't get to this part of my truck for a few years yet so I have no idea. Might want to give them a call and see what they say....
Old 10-17-2018, 12:31 AM
Jgood82
Jgood82 is offline
Jgood82 is starting off with a positive reputation.
Grille guard
Does anyone have or know someone who has a grille guard for an 86 f350? Not a full brush guard just grille guard
  #28
Old 10-17-2018, 07:37 AM
Olds64's Avatar
Olds64
Olds64 is offline
Jgood, what type of grill guard do you want? The OP; SCFlareside, posted various grill guards available from a supplier in post #2. It you want just a grill guard I would think the Base model outlined in post #2 would be the way to go. BTW, what do you want to use the grill guard for? If you want to use it as a push bar or a mount for a winch you might need one similar to the style in post #10. Hopefully someone can chime in with 1st hand experience. FWIW, the one I bought used is similar to the Traditional style in post #2.
  #29
Old 10-21-2018, 08:38 PM
84red's Avatar
84red
84red is offline
84red is starting off with a positive reputation.
Winch bumper
Does anyone know what other accessories they used to have? Winch bumpers? Looking for some mounts for my Warn classic (angled chrome 80s version). Right now it has squarebody Chevy mounts. Hoping to get it on soon, then I can toss these on!
SCFlareside
10-17-2018 08:32 AM
SCFlareside
06-17-2015 10:39 PM
Ronin007
New York Chapter
118
06-04-2008 08:19 AM
danielzink
1968-2013 Full Size Vans
08-11-2004 10:17 AM
Quick Reply: Grille and Brush Guards available for our Trucks
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
