'73 F-250 Axle Pivot Bushings - Ford Truck Enthusiasts Forums
Old 02-12-2018, 07:17 PM
surfcraft surfcraft is offline
surfcraft is starting off with a positive reputation.
I'm trying to get parts together that I'll need to swap front I-beams (and engines, actually) between a great running but rusty '73 F250 and a clean and straight '68 F250. Both front ends would be in need of new bushings.
The '72 has original drum brakes, so I'm considering swapping in the '73's front suspension with discs.
The parts catalogs that I've been looking at seem to show that the same bushings are used in both, except HD.
The '73's I.D. tag lists a GVW of 8100lbs. Does anyone know if that's the HD?
If so, it seems like my bushing choices may be limited to rubber, which would be fine but my experience with new rubber parts is that they don't hold up nearly as well as the old stuff.
Has anyone re-bushed HD I-beams and who were your sources?
Many thanks,
JW
Old 02-13-2018, 02:38 PM
Sorry I used the term "control arm" rather than "radius arm" in my original post.,
NPD lists a separate number for '73 HD radius arm bushings but not the axle bushings. They seem to be selling MOOG parts which might be the blue thermoplastic.
LMC lists a separate number for '73 poly axle pivot bushings but not the poly radius arm bushings
Dennis Carpenter doesn't differentiate at all, but I think they're selling rubber.
It seems to be only Poly bushings where I find any difference noted, but I can't make sense of those.
Could it be that the bushing sizes are the same, but the poly are not rated for use in the HD axle pivots?
Thanks,
JW
Old 02-13-2018, 03:05 PM
POPAJON POPAJON is online now
POPAJON has a brilliant futurePOPAJON has a brilliant futurePOPAJON has a brilliant futurePOPAJON has a brilliant futurePOPAJON has a brilliant futurePOPAJON has a brilliant futurePOPAJON has a brilliant futurePOPAJON has a brilliant futurePOPAJON has a brilliant futurePOPAJON has a brilliant futurePOPAJON has a brilliant future
Energy Suspension will be able to help you out .
Old 02-13-2018, 04:25 PM
Thanks, POPAJON---
Energy shows same parts for all, (4.7107 for the rad.arm and 4.3124 for the pivots) as does Rockauto for the Energy parts.
Same energy parts through Amazon: Amazon's fitment check gives the thumbs-up for the radius arm bushings, but thumbs-down for the pivots.
Are some sellers just more knowledgeable, or could this be a case of all the sellers repeating bad second or third or?...party info?
Hoping for the best hasn't always payed off for me...
Old 02-13-2018, 06:01 PM
NumberDummy's Avatar
NumberDummy NumberDummy is online now
Ford Parts Specialist
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
The '73's I.D. tag lists a GVW of 8100 lbs. Does anyone know if that's the HD?
Absolutely!
1973/79 F250 2WD with dual piston caliper disc brakes have H/D 12" x 2 1/2" rear drum brakes.
1973/76 F250 2WD with single piston caliper disc brakes have 12 1/8" x 2" rear drum brakes.
And: 1966/72 F250 Camper Specials (all 2WD thru 1976) and w/a 7,500 lbs. GVWR also have 12" x 2 1/2" rear brakes as do 1968/72 F250 2WD's with optional dual piston caliper disc brakes.
Old 02-14-2018, 08:50 AM
mofoco1 mofoco1 is offline
mofoco1 has a good reputation on FTE.mofoco1 has a good reputation on FTE.
My .02 but I would get the front set up from a 76 instead. I went thru this on my 75 SC build. The caliper set up is different on the 75.5ish and below. next to no pad choices, goes up considerably with the later. Look at my build https://www.ford-trucks.com/forums/1...2wd-build.html I went thru it so you don't have to.
Restoring 73 Camper Special F250 Front End decaruby 1973 - 1979 F-100 & Larger F-Series Trucks 17 09-18-2016 12:04 AM
Axle Pivot Bushing Replacement Treacy 1987 - 1996 F150 & Larger F-Series Trucks 0 07-05-2016 03:40 PM
2000 E250 front Stabilizer bar I-Beam bushings jerseymike 1968-2013 Full Size Vans 6 05-06-2016 12:36 AM
'73 F250 Trailer Special Front Axle Bushings Rynoride 1973 - 1979 F-100 & Larger F-Series Trucks 3 04-11-2016 03:45 PM
Radius Arm Bushing Job Coastal68 1967 - 1972 F-100 & Larger F-Series Trucks 4 03-27-2016 06:30 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
