Hood hinges What have i done wrong - Ford Truck Enthusiasts Forums
Old 02-12-2018, 03:09 PM
Pladsmand
Pladsmand is offline
Pladsmand is starting off with a positive reputation.
Frist the hood will not stay in upright position and I have to push the hood down on the rear end when i have closed it. Then
i turned the spring 1/2 turn, now the hood will stay upright but now i nearly can't push the hood down at the rear end
Old 02-12-2018, 05:09 PM
abe's Avatar
abe
abe is online now
abe has a spectacular reputation.abe has a spectacular reputation.abe has a spectacular reputation.abe has a spectacular reputation.abe has a spectacular reputation.abe has a spectacular reputation.abe has a spectacular reputation.abe has a spectacular reputation.abe has a spectacular reputation.abe has a spectacular reputation.abe has a spectacular reputation.
Are these original to the truck, used, NOS, Repops?
How did your hood close before?
Old 02-12-2018, 07:00 PM
Harrier's Avatar
Harrier
Harrier is offline
Harrier has a brilliant futureHarrier has a brilliant futureHarrier has a brilliant futureHarrier has a brilliant futureHarrier has a brilliant futureHarrier has a brilliant futureHarrier has a brilliant futureHarrier has a brilliant futureHarrier has a brilliant futureHarrier has a brilliant futureHarrier has a brilliant future
There has been some discussion on this topic.
I recall that lubrication on the pivot point that is hidden is important.
Could you also have possibly twisted the pivot points? Not sure if that is possible though.
These hoods have a reputation on not going down in back.
Old 02-12-2018, 07:16 PM
Harrier's Avatar
Harrier
Harrier is offline
Found a couple.
https://www.ford-trucks.com/forums/1...djustment.html
This is the one that discusses the hidden pivot point.
https://www.ford-trucks.com/forums/4...od-hinges.html
I thought I saw pictures before. This thread shows the pivot points.
https://www.ford-trucks.com/forums/9...justments.html
Old 02-12-2018, 08:23 PM
lfed's Avatar
lfed
lfed is offline
lfed is gaining momentum as a positive member of FTE.lfed is gaining momentum as a positive member of FTE.
I would take the hinges apart and make sure all the moving part are moving freely and then lube them up put the springs back where they were. with everything moving freely you should be able to figure out if the springs are weak or you just need proper alignment of the hinges. just my two cents.
Lloyd
Old 02-13-2018, 08:42 AM
bjmayberry2's Avatar
bjmayberry2
bjmayberry2 is offline
bjmayberry2 has a brilliant futurebjmayberry2 has a brilliant futurebjmayberry2 has a brilliant futurebjmayberry2 has a brilliant futurebjmayberry2 has a brilliant futurebjmayberry2 has a brilliant futurebjmayberry2 has a brilliant futurebjmayberry2 has a brilliant futurebjmayberry2 has a brilliant futurebjmayberry2 has a brilliant futurebjmayberry2 has a brilliant future
Iím pretty sure when aligning your sheet metal you START with the hood. Maybe it would be easier to get your hood working well and then add your fenders.
Old 02-13-2018, 08:49 AM
df85732's Avatar
df85732
df85732 is offline
Secret Agent
df85732 has a great reputation on FTE.df85732 has a great reputation on FTE.df85732 has a great reputation on FTE.df85732 has a great reputation on FTE.df85732 has a great reputation on FTE.
That's a good idea BJ! Less chance of scratching my newly painted fenders when I get to that point. Plus, much easier to reach the spring mounting bolts. Thanks for the tip. Reps coming your way!
Old 02-13-2018, 01:29 PM
Harrier's Avatar
Harrier
Harrier is offline
Here is a thread on front end alignment procedures.
https://www.ford-trucks.com/forums/1...ml#post9927171
Here is one of the bullet points in the post:
First look in my "extras gallery" for the hinge pictures, remove the springs and be sure the hidden hinge pivot shown is not frozen and working freely. Even new hinges can have this pivot tight or paint frozen, and if tight the hood will never close properly!
Old 02-14-2018, 11:27 AM
Pladsmand
Is the hingde collected rigth
Old 02-26-2018, 06:53 AM
Pladsmand
I still have problems whit the hood some one who have used hinges like i have posted a pictures will some one like this solve my problems and they are really expensive
3Mike6
1947 and Older Ford Trucks
07-27-2013 09:24 PM
Justin.Hoeben
05-21-2013 02:36 PM
alixrider
10-17-2011 07:59 AM
Cody_1948
06-18-2011 08:21 PM
blatherskite
01-10-2003 12:12 PM
Quick Reply: Hood hinges What have i done wrong
Contact Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
