What is normal brake wear?
I have 46,000 miles on my 2016 Super duty F350, Powerstroke 6.7L, single rear. Most of my hauling is with 4 passengers and a load in the bed of about 3-400 lbs. Once or twice a month I may have to pull a trailer loaded up with as much as 9,000 lbs. I always use the electric trailer brakes with TOW function engaged. The trailer brakes are new and I usually make sure that the truck is not performing more than its share of braking.
I have noticed, even when I am not towing, that the front brakes are much hotter (~ 300F) than the rear brakes (~125F). This is without load in the bed or a trailer behind.
Two weeks ago I looked at the brake liners while rotating my tires. The front liners are down to 1/8" and the rear liners are close to 3/8".
Is this normal?
My 2006 super duty did not do this.
I am wondering if there may be something wrong with the combination valve or something else. Both front brakes have identical wear.
I have extended warranty coverage and am hoping that this can be remedied in that plan. Booster, combination valve and calipers are covered in that warranty.
Is this normal?
With a lot of towing 8000 to 12000 pounds and with a fair amount of driving in the mountains my 2011 needed brakes at 100,000 miles. My 2016 only has 23000 miles on it so I don’t know how it will be on brakes. Unless you have a lot of stop and go driving 46000 miles does not seem normal for brake wear.
Normal brake wear falls into the same category as normal fuel economy. They are both totally dependent on driving style, terrain, and the type of travel. If pad wear is balanced side to side, there is probably no warrantyable claim. I’d say it’s normal for the fronts to wear at least as twice as fast as the rears.
Received 6,680 Likes
on
As the two eluded to above, take a look at the inside pads on the front and see if they match the outside pads. If even, then they are wearing evenly. No disrespect intended, but you see a lot more front pad wear with drivers that use both feet to drive(automatics). Also as they said, the front's wear more than the rears. The only truck that I've ever had that wears them evenly is my Excursion, and it's due to no longer pull anything any longer as I have the two duallies.
There are a lot of options on th tow setting. Gain is obvious and there are simple steps to set that properly, but you need to set "effort" correctly and set "electric" versus "electric over hydraulic" too. too. And as others have said, adjust trailer brakes - a big impact.
I have 60k miles on 2015 dually. 20k empty mostly empty 8-hour highway driving. 20k with 8k bumper pull with equalizer hitch and 8-hour highway driving. 20k with 16k 5 5er at max gcwr. That was more like 5 hours on highway.
I just pulled all wheel to grease pins. Pads hardly worn at all.
Is this normal?
Is this normal?
on
With respect to pad type, I'm not a fan of ceramic pads. I tried them on my wife's minivan and it was a significant downgrade in performance. My prior truck had ceramic pads and when I replaced them with semi-metallic the performance was soooo much better. Ceramic pads are great for low dust and not fading under heavy braking (like a race track). Otherwise, I'll take semi-metallic.
Hey, I eluded nothing. I _might_ have alluded about normal wear patterns.
Thanks everyone. I will be performing the brake pad change myself as it appears the consensus is that it would be nothing more than normal wear.
I have a tube of Permatex ceramic extreme brake parts lubricant (purple in color) that was recommended by the local parts store when I I said that I was not getting more than a year on my 2006 truck brakes before the guide pins were seizing.
Any thoughts on this lubricant? It is supposed to be rated to 3,000 deg F.
on
On my truck the OEM ceramic pads were Bosch and the replacement semi-metallic were also Bosch. I'll take great braking and dust over less braking and no dust.
on
