How long to heat engine with plug in
A warm engine is a happy engine, and less wear at start-up. Keep in mind less wear on the glow plugs too, so plugging in is waaaaaay cheaper than replacing the glow plugs and paying someone to replace them!
I figure coolant temp is in the 100*F to 120*F range....do you heat your garage to 120*F ??? I doubt it. The point is plugging in a vehicle is the best thing besides changing the engine oil, there is for your engine.
Block heaters reduce some of the wear and tear from a truly cold start, but they don't get anything up to full operating temperature.
Also, if you do use them, about two hours is all you need before you start up. Running them all night is a waste of electricity and doesn't help anything. A cheap timer that comes on a 4AM or so will pay for itself with the electricity savings.
I know some people who also wire up one of those 120V interior warmers to run at the same time, which helps take the chill off the inside, although in really cold temperatures, they don't get the inside "full warm" either.
I've found that having a battery tender/maintainer hooked up makes a bigger difference than a block heater, although obviously doesn't warm the engine oil/coolant at all.
I mostly just remote start my vehicles and let everything warm up that way.
How warm the block heater gets your coolant / oil is going to obviously be dependent upon how cold it is outside. I plug mine in all night long - I realize I'm not gaining anything by leaving it on all night, and I'm too lazy to buy a timer.
I don't think glow plugs are preserved much by plugging in a block heater, BII Plow Truck. They operate based upon a variety of parameters, but ambient temp is the crucial one since their purpose is specifically to warm the air being compressed in the cylinder. I do agree plugging in saves engine wear, and that's primarily the only reason I plug in. These engines start up well even when temps are below zero.
I read somewhere that Ford advises to plug it in at least 4 hours prior to starting for full effect. I wish I could remember where I found that information. So with that in mind I have mine on a timer to turn on 4 hours before I have to leave for work. Seems to work for me. We are typically in the Teens and twenties most of the winter for overnight low's.
My truck is kept in a heated garage where I have the thermostat set at 45, as low as it will go. I always back in, so the engine is toward the overhead door, where it much cooler that the other side of the garage where the thermostat and furnace reside.
I use a timer set for about three hours before I leave for work. I have the temp (Forscan) activated above the water temp gauge. I've seen the temp at startup as high as 135 degrees. As soon as the engine starts, that temp reading drops a LOT, like in half, or more. Too bad there isn't a circulation pump like there is on the backup generator at work!
I only have an 8 mile drive to work, but the block heater definitely helps it warm faster.
My commute is only 9 miles and I find the heater starts blowing (automagically) when the coolant temperature hits 100°F.
