2002 Ford Escape manual trans - front-end judder while coasting at 50-70mph - Ford Truck Enthusiasts Forums
Escape & Escape Hybrid Ford Escape, Ford Escape Hybrid, Mercury Mariner, Mazda Tribute
Old 02-12-2018, 07:05 AM
AVR2 AVR2 is offline
AVR2 is starting off with a positive reputation.
My 2002 Escape 2.0L with manual trans has started juddering when I coast, but only if I'm doing between about 50-70mph. Above or below those speeds it doesn't happen.
The judder feels like it's in the front suspension or driveline, it's not coming from the engine. It also only happens when I'm coasting, not at any other time. It's not an extreme "death wobble" sort of judder, it's more like I'm driving over a corrugated road surface like a washboard road. In fact the first time I noticed it, I thought it was simply poor road surface.
The way I induce it is simply to come off the gas pedal at typical freeway speeds. Everything's normal for a second or two, and then the judder starts. Two things will stop it happening - either I get back on the gas (as long as I'm on the gas pedal even the tiniest amount, there's no judder) or I throw it into neutral.
The front tyres are less than a year old, and the tie rod ends were replaced about a year ago.
I'm obviously hoping it's not suggestive of an internal transmission problem. Could it be a loose trans mount or something like that?
Old 02-12-2018, 02:59 PM
simonsi's Avatar
simonsi simonsi is offline
simonsi is starting off with a positive reputation.
Sounds like a CV joint in the driveshafts (2 on each driveshaft), to either front wheel, check them for play/movement, likely one is starting to go.
Old 02-12-2018, 06:11 PM
OK, thanks. I'll take a look.
Old 02-12-2018, 07:18 PM
got2bjoester got2bjoester is offline
got2bjoester is gaining momentum as a positive member of FTE.
Also, jack up the front end and after supporting it with jack stands, grab the top and bottom of the wheel and see if there's ANY wobble. There shouldn't be. Check both sides.
Indication of a failing wheel bearing.
Not loose? Use a pry bar to check the ball joint pinch bolt for slop. Skip ahead to 3:30...
Six Dealer Visits since 2016 and Still Not Fixed Checkerboard 1999 to 2016 Super Duty 35 12-15-2017 12:05 PM
2014 exp Rhythmic vibration 50-70 mph gcowan99 2011 & Newer Explorer 0 10-13-2017 11:04 PM
tranny judder bazzman1953 Ranger & B-Series 5 06-16-2017 11:53 PM
Cooper At3s cupping and vibration Treacy 1987 - 1996 F150 & Larger F-Series Trucks 5 01-10-2017 04:44 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
