Wanted to introduce myself.....
#46
Is there another name for this solenoid? I can't seem to find it anywhere. I am also looking to replace the other part next to the solenoid, what is that used for?
#47
https://www.rockauto.com/catalog/ema...olenoid%2C4188
starter solenoid on rock auto web site. All Ford cars had them from 60s till 90s.
Part next to the solenoid is a relay there used where more voltage or heavy duty fuse link
#49
The starter solenoid is also still available from Ford. It is part number B6AZ11450B.
Try getting those brand new from Chevrolet still. Eat your heart out Chebbie boys.
The relay next to the starter solenoid is actually the horn relay. That was part number C4AZ13853A. Discontinued.
The C4AZ13853A can be bought from:
Klimesh Motor Sales
563-562-3241
x
Green Sales
(800) 543-4959
x
The Lincoln/Mercury Old Parts Store
727-445-7551
#51
On another note............I recently bought new coiled brake line to redo my lines, I bought the 3/16 nickel/copper line that came with some fittings. Anywho, can I use this type of line to redo the transmission cooler lines that go from the tranny to the bottom of the radiator? Just trying to kill two birds with one stone here,
#52
Power Steering
Can anyone tell by the pictures if this is a Bendix or Ford
power steering gear box? I appears that the prior PO swapped out the front drums, power steering, and column from a 78' truck. Well, the power steering reservior is completely empty and it looks like the seals are shot. Just wondering if there is a direct replacement that won't break the bank or if I should by a rebuild kit. Can I use this for a replacement? I also want to replace the pressure line hose so knowing which one to buy is definately helpful.
#53
#54
#57
This is the GM column that I returned, notice the space around the brace
I am 6ft 230, plenty of room with the tilt column
For a little extra IDidit can customize it and make it even shorter
#58
Craftsman63
08-08-2016 03:39 PM
Joco
43
02-21-2014 05:14 PM
Daddywags
09-10-2004 12:30 AM
