1978 bronco dash lights suddenly quit
Howdy folks! Got another problemo with my Bronco. It had been a while since I messed with my bronco in the dark, but when I drove it this evening, I noticed none of my dash lights work. No heater control lights, gauge lights, gear selector, or wiper lights. All used to work. I replaced the gauge cluster and light switch to get them working in the first place. Any ideas?
The common mistake is to use the blue-with-red-stripe wire as a ground, since it shares a connector with the yellow switched-12V+ wire, and that will blow that fuse the first time you turn on the lights and hit the brake.
That blue-with-red-stripe wire is for the dial light in the original factory radio, so if it gets grounded, it will pop that fuse.
I'm not sure how the turn signal switch could play into it, but I guess the tail light bulbs could be routing the ground back to the gauge-light side.
But I'm still thinking that the problem is due to an errant grounding of your Instrument Panel lamp circuit, or of the tail light circuit. Dunno for sure that these trucks are like that, but every other Ford I've had shared the fuse between the tails and the instrument panel lamps.
Maybe the new cluster's IP PCB doesn't match the truck's wiring harness?
BINGO! Turns out the wire for the gear indicator light was pinched. Rerouted it and everything works perfect. Thanks guys!
Ben Samways
47
12-17-2017 03:29 PM
e30rik
12-26-2016 12:23 PM
dharte
11-22-2014 11:10 PM
The Terrible Blob
13
02-20-2014 10:56 PM
78 & 87 Super Cab
13
01-19-2013 05:56 PM
