Qs about D-44 spider gears, 4 in front? - Ford Truck Enthusiasts Forums
Go Back  Ford Truck Enthusiasts Forums > Bronco > 1978 - 1996 Big Bronco
Reload this Page >
Old 02-09-2018, 09:05 PM
78Broncoinpieces
78Broncoinpieces is offline
78Broncoinpieces is starting off with a positive reputation.
78 Bronco, 351M, C6, full time. 3.50 gears, factory stuff, nothing custom, yet...
Plan is to install a 460 some day and I'm concerned about the strength of the front diff. standard open 44 for now. looking at the parts manuals all I found was a 2 spider front diff. are there open diff carriers that have 4 spiders? I found trac-loks that have 4 spiders but don't want a trac-lok up front.
another option would be Detroit Tru track. great for a steering axle and no spiders gears to break.
the truck will never see hard-core off roading, just daily driving and "stupid-stuff". plus whatever I can get into around Ohio & Michigan.
thanks
Old 02-13-2018, 12:53 AM
78Broncoinpieces
Hmmm, I'll take the silence as a no. most likely will opt for a True Trac or Torsen.
Old 02-17-2018, 08:14 PM
fe390pc's Avatar
fe390pc
fe390pc is offline
fe390pc has a good reputation on FTE.fe390pc has a good reputation on FTE.fe390pc has a good reputation on FTE.
Well that same basic axle was installed in F250s with 460s in them so as long as you don't do 3500rpm drop into drive shots it should be good.
Old 02-17-2018, 09:14 PM
00t444e's Avatar
00t444e
00t444e is offline
00t444e is gaining momentum as a positive member of FTE.
I don't think they make a 4 spider open diff for the Dana 44 because the spider gears in the open diff rarely ever fail due to too much power, usually you will break a u-joint, driveshaft, or axle shaft long before a spider gear will fail. If you want to upgrade then the Truetrac is a great unit to run in the front axle.
Glaser67
12-31-2017 06:48 PM
BLDTruth
06-15-2017 01:29 PM
Russ74
03-30-2017 10:35 AM
cabloom300
03-22-2016 08:12 AM
axelgawn
03-04-2016 02:45 PM
Quick Reply: Qs about D-44 spider gears, 4 in front?
Contact Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
