1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Homemade Traction Bars
Old 02-09-2018, 08:15 PM
Obs7.3Powerstroker's Avatar
Obs7.3Powerstroker
Obs7.3Powerstroker is offline
So I’m fabricating my own traction bars. Was wondering if anyone else has made some up too. I have read you want make them the same angle as your drive shaft. Anyone else heard anything like that?
Old 02-10-2018, 04:55 AM
Chuck's First Ford's Avatar
Chuck's First Ford
Chuck's First Ford is offline
to what point??
traction bars are to prevent spring rap... SD using 3,4 springs.. should not rap
aka the rotation of the differential..
Old 02-10-2018, 09:55 AM
Obs7.3Powerstroker
I attached a camera to my frame and video taped my spring. Definitely have some pretty bad rap.
Old 02-10-2018, 11:39 AM
SuperDutyScaler's Avatar
SuperDutyScaler
SuperDutyScaler is offline
Ford's dont wrap?, ever drive your truck on sand or snow? It makes tracks like a bulldozer....little ripples as the rear is tweaking away
Old 02-10-2018, 12:06 PM
Obs7.3Powerstroker
MY truck also has a 4” lifting block, which I’m told will increase wrap. In the video I made my Spring was making an S shape. When you left off the gas you can feel the spring clunk back into its normal shape.
Old 02-10-2018, 12:54 PM
speakerfritz's Avatar
speakerfritz
speakerfritz is online now
traction bars are a plus on a superduty....it definitely makes a difference.
becareful how they bolt to the frame....while some preload is good....too much negative preload is not
Old 02-10-2018, 01:25 PM
don123's Avatar
don123
don123 is offline
Can you post a video of this?
Old 02-10-2018, 06:10 PM
projectnitemare's Avatar
projectnitemare
projectnitemare is offline
The true answer, it depends. Are they solid mount or with a shackle? Adding any lift block will make axle wrap worse since there is more leverage against the springs. Unless you know what you're doing best bet is to mimic a commercially made set. Most common problem usually is use of solid mounts and something breaks since the suspension will eventually bind.
Old 02-10-2018, 08:44 PM
Obs7.3Powerstroker
I am copying longhorn fab traction bars. Using third links from a tractor three point hitch for the rod ends and 1 1/2 pipe for the bars.
Old 02-11-2018, 05:47 AM
projectnitemare
That's where you are going wrong. I use dom for anything suspension related. Sure, structural steel pipe is strong; that debate has raged on for ages. I have yet to find threaded bungs for pipe. If you're going to use pipe, you need sch 80 for a 6 foot bar like you are looking to make. For a traction bar using pipe wouldn't be a crime but using those garage tractor links is. Use real rod ends, not the hitch links, they don't last.
Old 02-11-2018, 09:31 PM
Obs7.3Powerstroker
what is dom?
Old 02-11-2018, 10:23 PM
BioBurner's Avatar
BioBurner
BioBurner is offline
what is dom?
D.O.M.
Drawn Over Mandrel
It's a type of tube that doesn't have a weld seam like pipe does. Much stronger for the weight than pipe.
Old 02-14-2018, 12:35 PM
Obs7.3Powerstroker
Does anybody know how much the bars should be pre-torqued?
Old 02-14-2018, 12:43 PM
CampSpringsJohn's Avatar
CampSpringsJohn
CampSpringsJohn is offline
Since you're wanting to use heim joints (the ends off a top link for a tractor 3-point hitch) for your ends, what are you going to install that will allow some "give"?
Old 02-15-2018, 01:49 PM
Obs7.3Powerstroker
Not the way I have it set up right now. How would you make it so it has some give?
Quick Reply: Homemade Traction Bars
