Dual alternator pin out - Ford Truck Enthusiasts Forums
Old 02-09-2018, 10:57 AM
bio short bus bio short bus is offline
bio short bus is starting off with a positive reputation.
Ok so I did not disconnect my battery when removing lower alternator. My mechanic said I do not use alot of amps and could live without the lower unit. I did have some sparks when removing unit. I had a hard time removing plug. One wire pulled out of the harness. Charging system has been compromised. Did I blow a fuse? What should I look for? Only 12 volts at battery. I'm thinking I fried the top alternator. Can I just replace the internal regulator?
Thanks Bruce
01 E450
Old 02-09-2018, 04:35 PM
brian42's Avatar
brian42 brian42 is online now
brian42 is a splendid one to beholdbrian42 is a splendid one to beholdbrian42 is a splendid one to beholdbrian42 is a splendid one to beholdbrian42 is a splendid one to beholdbrian42 is a splendid one to beholdbrian42 is a splendid one to beholdbrian42 is a splendid one to behold
Can't help you with the wiring but I would definitely check the fuses to be safe.
Most alternators have the voltage regulator integrated into the unit these days. If you don't want to get a new one you can take it to a local electrical shop to see if the can replace the regulator or rebuild it for you.
I went down that road awhile back and did not get a warm fuzzy from any of the shops I talked to, plus the price they wanted to do it was not much cheaper than just getting a brand new one.
Old 02-09-2018, 08:50 PM
Walleye Hunter Walleye Hunter is online now
Walleye Hunter is a name known to allWalleye Hunter is a name known to allWalleye Hunter is a name known to allWalleye Hunter is a name known to allWalleye Hunter is a name known to allWalleye Hunter is a name known to all
If he's not going to use the other alternator is there any chance he can swap them out?
Old 02-09-2018, 10:54 PM
Stebs Stebs is offline
Stebs has a great reputation on FTE.Stebs has a great reputation on FTE.Stebs has a great reputation on FTE.Stebs has a great reputation on FTE.Stebs has a great reputation on FTE.
There's are fusible links between the alternators and the battery... you may have blown those...
Old 02-09-2018, 11:51 PM
fuseable links
That is where I am at now. Thinking I have fuseable link issues. I will check tomorrow to see if I have voltage at the plug. I do have voltage at top alternator and 12 volts at positive post of upper. I know I have no voltage at B+ terminal of second alternator . I have to trace where it leads before getting to battery.
Does anyone know what the fuseable links look like
I think I got this figured out at this point, voltage at both alternators piggy back each other
Old 02-10-2018, 12:31 AM
Colorado350's Avatar
Colorado350 Colorado350 is online now
Colorado350 has a great reputation on FTE.Colorado350 has a great reputation on FTE.Colorado350 has a great reputation on FTE.Colorado350 has a great reputation on FTE.Colorado350 has a great reputation on FTE.
Here's a good thread with pictures,...
https://www.ford-trucks.com/forums/1...tor-eater.html
Old 02-10-2018, 08:50 AM
pirschwagon pirschwagon is offline
pirschwagon has a very good reputation on FTE.pirschwagon has a very good reputation on FTE.pirschwagon has a very good reputation on FTE.
The Second Alternator is not loaded until the Primary Alternator exceeds 75% -
80% of its capacity (Amperage). Therefore, it is free spinning.
The Harness is interconnected to the Primary in a single molded Harness. If one is disconnected, the other will not work - It's Closed Loop. There is a way to close the loop but I'm having trouble finding the Connector View. I will look later - Very Busy Day! Two 6.0L Jobs. May get back on later this evening.
To save yourself $1000.00 or more for parts only:
ALWAYS disconnect the Negative Cables BEFORE working on the Electrical System. Among things that are very fragile to electrical current spikes, the PCM and GEM.
Throw the Keys in the Woods when performing Electrical Work. NEVER leave them in the ignition - Ask me how I know!
Old 02-10-2018, 11:12 AM
That is an awesome thread. I really got the concept of fuseable links.
Thanks
Old 02-10-2018, 11:24 AM
I dont think I want to ask why you should have thrown the keys in the woods I have a feeling it cost you alot of money.
You are starting to make me feel like I may not have to much damage being the *** I am(I can take this out with out touching any metal..."wtf was I thinking...I know better than this, Oh **** I am ****ed...Time to clean up my mess now")
Just took the alternator out of the top. The new one I have is incorrect so I might as well have them test it now. This is a new revelation that it is a closed loop and adds some wait to my uneasy feeling. The dummy light does not go one, I have gotten home the last three nights without dying on the side of the road. Charging system does not show signs of charging but it is staying alive. My gauge on dash stays in acceptable range for me but my digital gauge in the information box gets as low as 11.2 yesterday causing me to retreat with no heat and turning headlights on and off as needed, by the time I stopped to get fuel new alternator leaving truck running digital reading was back to 11.8
Old 02-10-2018, 12:24 PM
The Alternator (Open Loop) will not activate the Voltage Regulator unless the Circuit is competed (closed loop). There are three pins on an isolated Alternator.
(+), (-), and (F).
The Dash Lamp (which has its own fuse), goes off when when the circuit with a Diode is energized, closing the Field Circuit, which, in turn, closes the Voltage Regulator sending Electricity to the Vehicle and Batteries.
I still am looking for the Connection Di gram. You will have to cut/splice two wires for the Second Alternator or the Primary will not allow current to flow from the (B+) Post
If you look at the Schematics (earlier post), you will see the Lamp Indicator and wiring.
Keys, Long Story Short: I had a Job that payed $600. When I was done, it cost me $1,200 from my Pay Check.
Old 02-10-2018, 03:39 PM
Here is my update. Alternator system has been fine for 2 years. I have been concerned for the last couple of days about the pin out of the lower harness, today I discovered that that harness is not even plugged in. I have not located the destination of the B+ terminal I am going to have to remove my battery to locate where it is going.
I hope you can find the diagram. What I am not understanding is based on what I have explained to you in this post how connecting the B+ lead to the second alternator would complete the loop. My son Grant is making this post for me sense I am trying to go to work today with the truck so I am not sure if you have sent the diagram but I will check when I get home. Thank you
Old 02-10-2018, 09:53 PM
I am now home and what a crazy day. The ford information center gave me voltage as low as 11.8 but actually hung around 12 and went as high as 13. The only other thing I am thinking... what is the ground wire connected to the lower alternator. I never connected it!
I had to run wipers and lights most of the day as well as the pumps I use to vacuum my tank to collect veggie oil, they pull about 12 amps, and the heat.
Old 02-11-2018, 08:44 AM
Personally, I make a Negative Cable and run them from the Alternator CASE BOLT to the Negative Terminal for both.
Old 02-12-2018, 12:25 PM
brian42's Avatar
My new alternators came with a case bolt but my OEM ones did not (but the bolt hole is there). I'm not sure what the size/pitch of the bolt hole is but you can add the case-to-negative cable to your original alternator(s) as well.
Old 02-12-2018, 08:32 PM
ExPACamper ExPACamper is offline
Almost there
ExPACamper has a brilliant futureExPACamper has a brilliant futureExPACamper has a brilliant futureExPACamper has a brilliant futureExPACamper has a brilliant futureExPACamper has a brilliant futureExPACamper has a brilliant futureExPACamper has a brilliant futureExPACamper has a brilliant futureExPACamper has a brilliant futureExPACamper has a brilliant future
Quote:
I ran a ground wire from the alternator mounting bolt to the grounding bolt through the driver side air intake plenum. So this is all wrong?
lower alternator pigtail wiring bio short bus 1999 to 2016 Super Duty 4 02-10-2018 11:56 PM
Escape Alternator replace the easy way yeksun Escape & Escape Hybrid 17 09-01-2017 01:23 PM
Help! Questions about proper voltage, alternator, etc. MoreBoostPlease 6.0L Power Stroke Diesel 6 10-04-2016 07:49 PM
Bad alternator tests good! mrlexse 1997-2006 Expedition & Navigator 4 09-09-2016 06:42 PM
110 amp alternator replacement? coolfeet 6.0L Power Stroke Diesel 20 04-08-2016 01:40 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
