Ford 6.7L DEF tank Heater - Excessive failure rates - P20BA - Page 6 - Ford Truck Enthusiasts Forums
Go Back  Ford Truck Enthusiasts Forums > Diesel > 6.7L Power Stroke Diesel
Reload this Page >
  #76
Old 12-13-2018, 04:46 PM
kper05's Avatar
kper05
kper05 is offline
kper05 has a brilliant futurekper05 has a brilliant futurekper05 has a brilliant futurekper05 has a brilliant futurekper05 has a brilliant futurekper05 has a brilliant futurekper05 has a brilliant futurekper05 has a brilliant futurekper05 has a brilliant futurekper05 has a brilliant futurekper05 has a brilliant future
I must have had to fill mine. I have a $7 charge (no way that's diesel) at a Shell I use that has a DEF pump on the same day as the Ford invoice but I can't remember if it was low prior to taking it in, knowing they would need to drop the tank.
I'm not locating anything that states BC3Z-5J225-L superseded "x" part number, at least for the 2011.
  #77
Old 01-18-2019, 03:14 PM
mechelement's Avatar
mechelement
mechelement is offline
mechelement has a good reputation on FTE.mechelement has a good reputation on FTE.mechelement has a good reputation on FTE.
Mine was replaced, scheduled for the 3rd, but replaced on the 7th. $100 warranty deductible. As far as I know, they installed the same part that is prone to failure.
  #78
Old 01-28-2019, 05:24 PM
kid50
kid50 is offline
kid50 is starting off with a positive reputation.
P20BA Fix
So, Ford has acknowledged this is a problem but has yet to extend coverage to my truck (2015 F350 with 69K). I was able to get a new heater for $160 and the swap was surprisingly easy. It took just over one hour with a basic socket set. If you have an iota of mechanical ability, do it yourself. There are good videos available that will walk you through the process. I was quoted $900 at the local dealership. At 100K, some of this stuff may fall off....
  #79
Old 01-28-2019, 06:33 PM
kper05's Avatar
kper05
kper05 is offline
For systems designed for double that mileage, it's amazing how that happens! /s
  #80
Old 02-11-2019, 02:14 PM
BirdDog13
BirdDog13 is offline
BirdDog13 is starting off with a positive reputation.
I have to replace the heater on my 15 super duty also. Can you tell me where you found the part and what that part number was? I tried at my local part store, and they just gave me blank stares.
  #81
Old 02-11-2019, 02:43 PM
dirthawg's Avatar
dirthawg
dirthawg is offline
dirthawg has a good reputation on FTE.dirthawg has a good reputation on FTE.dirthawg has a good reputation on FTE.
Keep an eye on the price of those dorman units. Looking around online they are as much if not more than the OEM. Walmart.com was the cheapest I could find the Dorman unit.
OEM - https://parts.autonationfordwhitebea...-l?parent=1173
Dorman - https://www.walmart.com/ip/Dorman-90...ater/140319689
  #82
Old 02-12-2019, 07:37 AM
L3dford
L3dford is offline
L3dford has a good reputation on FTE.L3dford has a good reputation on FTE.
The DORMAN (904372) is $135.79 on Rockauto. That's where I purchased mine.
  #83
Old 02-12-2019, 01:46 PM
kid50
kid50 is offline
Jegs
See pic
  #84
Old 02-13-2019, 01:15 PM
16-F250
16-F250 is offline
16-F250 is starting off with a positive reputation.
Had my first failure and I'm not even to 22k miles yet on a 2016. This truck is going to put me on a first name basis with the local dealership if it keeps going like this. 2 NOX sensors and the tank heater in the past 45 days.
DieselMama
13
02-12-2019 03:08 PM
Ford Truck Dude
11-15-2017 11:35 PM
2011F-250KR
49
07-16-2017 11:43 AM
Glenn Colorado
03-26-2017 06:59 PM
DLC f250
03-08-2016 09:13 PM
Quick Reply: Ford 6.7L DEF tank Heater - Excessive failure rates - P20BA
Contact Us About Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
  • Ask a Question
    Get answers from community experts
Question Title:
Description:
Your question will be posted in:
