Ford 6.7L DEF tank Heater - Excessive failure rates - P20BA - Page 5 - Ford Truck Enthusiasts Forums
Go Back  Ford Truck Enthusiasts Forums > Diesel > 6.7L Power Stroke Diesel
Reload this Page >
  #61
Old 12-09-2018, 07:37 PM
mechelement's Avatar
mechelement
mechelement is offline
mechelement has a good reputation on FTE.mechelement has a good reputation on FTE.mechelement has a good reputation on FTE.
Originally Posted by kper05 View Post
What is the specific DTC? Depending on the severity, the CEL will appear/clear but the DTC is most likely still active. The P20BA for the DEF heater/sender assembly will not impact active regeneration of the DPF since SCR is for a separate purpose.
For example, when my #5 fuel injector was failing, the DTC would remain but the CEL was off more than it was showing.
It didnít say. It said performance failure of some sort and it pertained to the DEF heater.
CEL came back after driving on a dirt road. Prior to this, full regen and no CEL.
  #62
Old 12-09-2018, 07:42 PM
mechelement
Double post.
  #63
Old 12-09-2018, 07:44 PM
yukondiesel
yukondiesel is offline
yukondiesel is starting off with a positive reputation.
Question Another engineering marvel?
Originally Posted by jetskier View Post
It's 5/50k not 8/80 for over 8500# GVWR. See the warranty guide.
It's hard to say what Ford's stance is on this failure at a given mileage. It is an electric heating element so they do get fatigued over time. Not to mention it's submerged in Urea.
Why not put the heating element OUTSIDE the tank instead of IN the caustic urea? That would even make replacement easier?
  #64
Old 12-09-2018, 08:59 PM
mechelement
Kind of like a heat tape system for water, DWV and LP/natural gas?
  #65
Old 12-09-2018, 09:35 PM
kper05's Avatar
kper05
kper05 is offline
kper05 has a brilliant futurekper05 has a brilliant futurekper05 has a brilliant futurekper05 has a brilliant futurekper05 has a brilliant futurekper05 has a brilliant futurekper05 has a brilliant futurekper05 has a brilliant futurekper05 has a brilliant futurekper05 has a brilliant futurekper05 has a brilliant future
That's an idea. Double layer though. Protect the heater unit from whatever crap is on the road and then there is another plastic layer to the DEF.
  #66
Old 12-11-2018, 10:08 AM
yukondiesel
DEF Forever?
Yup...seems simple doesn't it? Since I don't know how the systems works, does the feed line/system need protection as well?
  #67
Old 12-11-2018, 10:11 AM
yukondiesel
Even better! just make the process for replacement easy, like the heat element coud screw off like a spin on oil filter with just a simple WEATHERPROOF electrical connecter?
  #68
Old 12-11-2018, 10:29 AM
12F350
12F350 is offline
12F350 is starting off with a positive reputation.
Urgent!
tnis may have been listed but I don't want to scroll the entire chapter.
Ford has a service bulletin on this.
Customer Satisfaction Program 18M01.
It addresses the reductant heater and sender issue. CEL and possibly a " reduced power mode"
Its good till December 31, 2018 regardless of mileage.
  #69
Old 12-11-2018, 10:55 AM
gsxr1300
gsxr1300 is offline
gsxr1300 has a very good reputation on FTE.gsxr1300 has a very good reputation on FTE.gsxr1300 has a very good reputation on FTE.
When they replace the heating element do they have to dump the tank?
As soon as I got my truck back the 800 mile till empty light came on.
  #70
Old 12-11-2018, 11:11 AM
12F350
12F350 is offline
That I do not know. Someone else may be able to comment on that. I brought mine in for a CEL today and the customer satisfaction recall. Mine was a plugged EGR cooler AGAIN.
  #71
Old 12-11-2018, 12:21 PM
gsxr1300
gsxr1300 is offline
How do you use your truck? Anyheavy towing?
  #72
Old 12-11-2018, 12:49 PM
12F350
12F350 is offline
If that question is for me...I tow VERY little. I do a lot of highway driving though.
  #73
Old 12-12-2018, 11:28 AM
mechelement
FYI, thereís a VIN cutoff on this little deal. My VIN falls outside the coverage, but thankfully the warranty I bought covers the repair.
  #74
Old 12-12-2018, 08:05 PM
HDSlowride
HDSlowride is offline
HDSlowride is gaining momentum as a positive member of FTE.
They replaced mine last week. Local Ford dealer. Mileage was 46469. DEF tank was full when I took it in and full when I got it back. No note of adding fluid after the remove and install reductant tank assembly. Parts and labor were all covered. No cost to me.
I had one instance a few weeks ago of a CEL and message "exhaust fluid system fault" that went out on its own an hour or two after it came on.
  #75
Old 12-13-2018, 10:19 AM
gsxr1300
gsxr1300 is offline
Thanks maybe I was just getting low.
Anyone know if the r4eplacement part has been upgraded?
Quick Reply: Ford 6.7L DEF tank Heater - Excessive failure rates - P20BA
Contact Us About Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
  • Ask a Question
    Get answers from community experts
Question Title:
Description:
Your question will be posted in:
