Keep rebooting your BlueTooth MX by unplugging and clicking the little yellow switch, you should see a rapid blinking of the blue light. then also restart your bluetooth on the device your connecting too at the same time. they will connect. HAve you entered your licence code in Forscan? If not, or even try re-entering. It took me a few tries but once connected its easy peasy.
The computer and adapter are connected. It finds the vehicle and connects to it. Then it says it cannot identify the vehicle. I looked in the log. It knows that it found a Ford vehicle. It identifies the truck computer module. Then says that it can't identify it.
I don't have a 2018 so I am not sure what the exact problem was, but just to confirm - you do have the latest version of Forscan they released that fixed some issue with 2018's - right?
