Turbo ordered 364.5 sxe - Page 9 - Ford Truck Enthusiasts Forums
Old 06-11-2018, 02:10 PM
brandon_oma#692's Avatar
brandon_oma#692
brandon_oma#692 is offline
brandon_oma#692 has a great reputation on FTE.brandon_oma#692 has a great reputation on FTE.brandon_oma#692 has a great reputation on FTE.brandon_oma#692 has a great reputation on FTE.brandon_oma#692 has a great reputation on FTE.
Updates from the morning coffee thread
Originally Posted by brandon_oma#692 View Post
Put the truck to work today. Picked up a 2001 5.4 2wd excursion. Radiator leaks, not sure what else is needed. Ac works, will park it till I can dig into it end of July or start of August. Super clean body, doors are the cleanest I have seen in Illinois lol $500.
Hauling it home. What does an excursion weigh? 6k or so? Truck and trailer are 18k empty so I'm guessing 24k. Climbing up a hill into the wind. Seat belt is flapping around making a bunch of noise. 4th gear 2500 2600 rpm. Boost at 1:1 up to 25 lbs. Backed off to make the corner at the top of the hill then downhill into town. Gearhead light tow economy tune.
https://youtu.be/_69iWEXrwJc
Originally Posted by Tugly View Post
I think the Excursion weighs in at about 8K
Originally Posted by Sous View Post
Hauling 26K lbs in a light tow tune and below 1200 degrees looks good. I am looking forward to getting my T4/SXE kit ordered once the new to us camper modifications slow down soon.
Couple screenshots from video. EBP hit 25.1 and boost made it to about 24 or 25. Pretty close to 1:1 sometimes better than 1:1 as the EBP was fluctuating a bit
ICP 2862
IPR 38.7
FIPW 3.2
Go Pedal 72%
​​​​​​​EGT 1100-1200
  #122
Old 06-11-2018, 03:02 PM
Sous's Avatar
Sous
Sous is offline
Sous has a brilliant futureSous has a brilliant futureSous has a brilliant futureSous has a brilliant futureSous has a brilliant futureSous has a brilliant futureSous has a brilliant futureSous has a brilliant futureSous has a brilliant futureSous has a brilliant futureSous has a brilliant future
Brandon, I am pleased every time I see you post something about the SXE. Although, it only makes me want to order the T4 and SXE sooner than I really need to. I hate having too many unfinished projects, and the camper is still on the top of our list right now. Also, it is too hot in the garage to spend a lot of time in there working on the T4/SXE, so it will have to wait until the fall. That way I can get other projects done and then be 100% focused on the truck.
Looking good though, your numbers are great and not far from what Akcooper9 sees and what I should see based on the injectors. The other fellas running the SXE's have various injector setups, so their results will be different then ours (the three of us) that are running stock or close to stock injectors.
Keep the pictures coming, as much as it hurts to see them.
  #123
Old 06-11-2018, 04:31 PM
brandon_oma#692
Did some hunting online for ways to find the grade of a road and it seems to be between 5% and 6.5% for that hill in the video bringing the excursion home.
Looked up the gravel road by where we rent storage for some tractors and that is 9% on 1 side and 10% on the other. When I pull on to the road headed home you are already heading uphill. Heading home trailer loaded I leave it in low but if empty I shift into first. 1 lane washboard road and blind hills. Headed there I almost stop at the top of the hill and shift into first since you are still descending when you pull into the driveway.
  #124
Old 06-11-2018, 08:37 PM
akcooper9's Avatar
akcooper9
akcooper9 is online now
akcooper9 is gaining momentum as a positive member of FTE.
I just go back from a 2100 mile trip to Durango Colorado and back to North Texas towing the 5er. The SXE was awesome. I pulled all but 3 hills in 3rd gear with EGTs at 1100 degrees or less with boots between 15 and 20 PSI max.
The 3 times I had to drop to second was due to switch back turns that required speeds below 45 MPHs. Some as low as 20 MPH. Steepest hill was at 10K foot of elevation and just keep climbing. Trucks settled in at 45MPH and just did awesome!
This was all with Dusty @ 1023 medium tow tune. His tune is 100 degree's cooler then PHP's server tunes.
It was very nice to be able to set the cruise and enjoy the drive with not worrying about EGTs
  #125
Old 06-17-2018, 01:06 PM
jhl3's Avatar
jhl3
jhl3 is offline
jhl3 is a splendid one to beholdjhl3 is a splendid one to beholdjhl3 is a splendid one to beholdjhl3 is a splendid one to beholdjhl3 is a splendid one to beholdjhl3 is a splendid one to beholdjhl3 is a splendid one to behold
Do any of you guys know the torque specs for the turbine and compressor housing bolts for the 300 series. The bolts were barely more than finger tight on the 366 that I received. I could be wrong but that just doesn't seem to be tight enough for something that has parts that rotate at 100k+ rpm's. I have searched online and cannot find them on BW's site.
  #126
Old 06-17-2018, 08:10 PM
brandon_oma#692
Originally Posted by jhl3 View Post
Do any of you guys know the torque specs for the turbine and compressor housing bolts for the 300 series. The bolts were barely more than finger tight on the 366 that I received. I could be wrong but that just doesn't seem to be tight enough for something that has parts that rotate at 100k rpm's. I have searched online and cannot find them on BW's site.
However tight I could get them with a wrench when it was already installed.
  #127
Old 06-17-2018, 09:02 PM
jhl3's Avatar
jhl3
jhl3 is offline
Thank you, Brandon. It makes me feel better to know that someone else has had success with this approach. Even though it does not inspire confidence for me, Gudentite is what I went with since the BW instructions allude to torque specs but don't elaborate. I hope to have some hot exhaust gas flowing through this thing sometime tomorrow since I am two days behind schedule already.
I live about 15 miles from the factory that built the 366: I may give them a visit to see if I can get some clarifying info for everyone.
  #128
Old 06-18-2018, 04:42 AM
akcooper9's Avatar
akcooper9
Agree, even if you find a torque spec you will never get a torque wrench in there.
  #129
Old 06-18-2018, 06:58 AM
jhl3's Avatar
jhl3
jhl3 is offline
Thank you for the additional clarification. I have access to a open-end interchangeable-head torque wrench, I guess that is what it is called, that would do it; however, using it would require installing and then clocking the turbo, placing index marks on the housings and center, then removing the turbo, torquing the bolts and then re-installing the turbo....maybe twice, which is a royal PITA and not something that I want to do since I have limited use of my left hand.
I now feel even better about "gudentite"! Thank you all, again.
  #130
Old 06-18-2018, 06:45 PM
00t444e's Avatar
00t444e
00t444e is online now
00t444e is gaining momentum as a positive member of FTE.
Did you have enough power to make that climb at 70 mph in overdrive if you wanted to? Thats how I like to tow on the highway, I only downshift when egts get to high.
  #131
Old 06-19-2018, 08:48 AM
brandon_oma#692
I think so if it did not have the curve at the bottom and was not a 55 speed limit. I don't think I could have accelerated from 50 to 70 but I think I could have maintained 70. You have to slow a little for the curve at the top. I usually go around the curve at the top between 45 and 50 with a trailer even empty, the sign says 45 . Then it is downhill to a speed trap entering town.
SRBF150
200
06-28-2018 10:43 AM
fordf348
12-04-2017 10:27 AM
fordf348
11-04-2017 07:53 AM
percyad
1999 to 2016 Super Duty
10-31-2017 11:14 AM
Oxfordbp
2017+ Super Duty
03-26-2017 02:22 PM
Quick Reply: Turbo ordered 364.5 sxe
Contact Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
