Clogged Crankcase Breather?
Old 02-06-2018, 09:59 PM
nolszewski
nolszewski is offline
nolszewski is starting off with a positive reputation.
Hi,
I have a lot of smoke coming out of the crankcase breather on the driver side valve cover, oil fill cap, and dipstick tube when the truck is up to operating temp. I've done some research and got the idea I may have an issue with the crankcase ventilation system. Is this correct? Or is it something else? I have absolutely no air pressure coming out of my oil fill cap. I know some smoke is normal, but I can see the smoke leak out from under the hood if I look closely enough.
Thanks for your time
Nathan
Old 02-07-2018, 05:28 PM
z31freakify's Avatar
z31freakify
z31freakify is online now
z31freakify is a splendid one to beholdz31freakify is a splendid one to beholdz31freakify is a splendid one to beholdz31freakify is a splendid one to beholdz31freakify is a splendid one to beholdz31freakify is a splendid one to beholdz31freakify is a splendid one to behold
Could be clogged, easy enough to remove it and clean it with parts cleaner. Also how old is your oil? Try changing it woth another brand next go around.
Old 02-08-2018, 01:40 PM
Talyn's Avatar
Talyn
Talyn is offline
Talyn has much to be proud ofTalyn has much to be proud ofTalyn has much to be proud ofTalyn has much to be proud ofTalyn has much to be proud ofTalyn has much to be proud ofTalyn has much to be proud ofTalyn has much to be proud of
I took the filter out of mine and it vents straight to the back bumper.
Old 02-08-2018, 01:42 PM
nolszewski
Thanks for the replies. So is a clogged breather a diagnosis for smoke? Since I don’t have abnormal blowby? I’m not sure what’s causing it
Old 02-08-2018, 01:49 PM
Talyn's Avatar
Talyn
Talyn is offline
Blowby has oil in it.
inside the breather is a mesh screen. That will eventually load up with so much oil it doesn't "filter" anymore.
Most of us flip it around and send it to atmosphere as the turbo system will suck oil into the turbo through the breather.
I had mine flipped around for a while with the filter and it just wasn't making me happy, so i pulled the screen out.
I figure if anything wants to crawl up 15 feet of tubing into the motor, let it go for it.
Old 02-09-2018, 08:35 PM
oldbird1965's Avatar
oldbird1965
oldbird1965 is offline
oldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to behold
Hi Talyn, mine is to the back of the drivers door without any level spots or up turns. I don't see how you can get it back to the back bumper without any spots where the oil can pool causing back pressure?
Old 02-14-2018, 11:43 AM
RÖENTGEEP's Avatar
RÖENTGEEP
RÖENTGEEP is offline
FOREIGN GURU
RÖENTGEEP is a splendid one to beholdRÖENTGEEP is a splendid one to beholdRÖENTGEEP is a splendid one to beholdRÖENTGEEP is a splendid one to beholdRÖENTGEEP is a splendid one to beholdRÖENTGEEP is a splendid one to beholdRÖENTGEEP is a splendid one to beholdRÖENTGEEP is a splendid one to behold
Arrow
When I did the mod, it went back to the back bumper, and yes its impossible going straight, and thinking about those possible pools I cut it and now, is like yours in the back of the drivers door, and at the begining going over the break booster.
Old 02-16-2018, 02:16 PM
Talyn's Avatar
Talyn
Talyn is offline
Mines got bows it in all the way.
I dropped it a while back and barely any oil came out of it.
If you got a ton of oil in yours, then you got some issues.
You also have to make sure you run it up and over the brake booster before you run it down.
fordflaresides
General Automotive Discussion
07-21-2004 08:33 PM
luke_trash
04-11-2003 01:23 PM
brown 4x4
12-16-2001 10:22 AM
DannyP
03-23-2001 11:07 PM
nissanjon
07-29-1999 10:52 PM
Quick Reply: Clogged Crankcase Breather?
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
  • Ask a Question
    Get answers from community experts
Question Title:
Description:
Your question will be posted in:
